Thread: e85 swap questions
Results 21 to 40 of 67
  1. #1 Re: e85 swap questions
    Banned
    Jan 2013
    maryland
    Being that E85 was never in my car modding future i can say that this has to be the best engine mod for this car pound for pound! Im currently on a stock pump but upgrading to a aem pump this week because of my pulley swap and i'll drop from a 3.0 to a 2.8 by that time i saw 5* of knock on my Cammed/ Heads /Header/ Genv /3.0 Pulley setup driving the car now i have no knock!
    Sent from my LG-E980 using Tapatalk
  2. #2 Re: e85 swap questions
    Quote Originally Posted by jayroca View Post
    Let me guess...... Runs a hell of a lot better now that it ever did with a (worthless) intercooler too huh!?
  3. #3 Re: e85 swap questions
    Banned
    Jan 2013
    maryland
    Quote Originally Posted by 98ChainStretcher View Post
    It wasnt worthless lol but i would say its a better mod along with reptiles tune lol
  4. #4 Re: e85 swap questions
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    stock pulley and you still have knock on headers? You need to look elsewhere for your knock issue
    04 GTP -HAI, 1.9 rockers.
  5. #5 Re: e85 swap questions
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    I think with e85 some sway bars and braces, and that car should be a different beast.
    with the e85 and 42# injectors does the maf and o2 sensor still compensate for lean and rich conditions?
    I understand how e85 raises power and lowers spark knock, but i just want to make sure its definitely ok to run without a tune.
    I guess it was pounded into my head that any major change requires tune.
    If it runs like normal (not rich or lean) then it will definitely be one of my first mods. How small of a pulley can i run on a stock car with the 42# E85 SETUP
  6. #6 Re: e85 swap questions
    May 2012
    Where winter never ends
    If you use 42.5# injectors you dont need a tune as they are 30% larger and e85 requires around a 30% adjustment. Any other injector type you will need a tune for e85. If its possible I still recommend getting an in car tune from a local tuner
    2000 Regal - Winter Beater
  7. #7 Re: e85 swap questions
    Sep 2014
    Richmond Virginia
    Quote Originally Posted by adecker View Post
    what sort of pulley should i be able to run?
    Theres a local place that will do initial dyno tune for 500, and subsequent tunes for 100$ probably hit them up when i go turbo.
  8. #8 Re: e85 swap questions
    Aug 2013
    Sandy, UT
    Quote Originally Posted by 04lss View Post
    Which ever one doesn't KR.
  9. #9 Re: e85 swap questions
    Sep 2014
    Richmond Virginia
    Quote Originally Posted by SnowTh1ef View Post
    guess ill start with a 3.4 and move down if it doesnt kr
  10. #10 Re: e85 swap questions
    May 2012
    Go richer as temp gets higher... or there is a table that adjusts fueling based on WoT Time
  11. #11 Re: e85 swap questions
    May 2012
    There is your problem....
  12. #12 Re: e85 swap questions
    Aug 2013
    Sandy, UT
    meh 42.5ers and e85 will kill his knock real good if that is his only issue.
  13. #13 Re: e85 swap questions
    Mar 2014
    Tucson
    Winter's coming so I'm curious to see how it reacts to some "cold" air. Cold being mid 50's.
  14. #14 Re: e85 swap questions
    May 2012
    lol... Thats cute... cold..50* haha try -20 here...
  15. #15 Re: e85 swap questions
    Aug 2013
    Sandy, UT
    AAALLLLLLLL the dense cold air up in the midwest haha
  16. #16 Re: e85 swap questions
    Mar 2014
    Tucson
    Nope! We moved away from that. I miss the change in the seasons, but not the cold.
    And the rust! HAHA!
  17. #17 Re: e85 swap questions
    Aug 2013
    Sandy, UT
    Quote Originally Posted by BrandonHall10 View Post
    And the rust! HAHA!
    Yeah.... lets not talk about how much falls off the bonneville every time i lift it up.
  18. #18 Re: e85 swap questions
    Mar 2014
    Tucson
    Okay, back on topic for a second...
    Assuming someone does the 42.5 injectors because they can't tune, is there any advantage to doing a hard reset on the PCM once the e85 is in the system? Or just drain tank, swap injectors, fill with corn gas and go?
  19. #19 Re: e85 swap questions
    Feb 2009
    flintnasty MI
    Good question.
    The answer is not really... you mostly just want to take it easy and roll into about 40% throttle a bunch of times before you get carried away with hard core racing.
  20. #20 Re: e85 swap questions
    Mar 2014
    Tucson
    Good question.
    This will be very difficult for me.
  1. Swap questions
    By Bluemagic in forum General Grand Prix Discussion
    Last Post: 05-17-2013, 08:38 AM
  2. Top swap questions
    By killer84 in forum General Tech Discussion
    Last Post: 12-17-2010, 08:28 PM
  3. Some top swap questions
    By Traeger2591 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-23-2009, 07:45 PM
  4. Swap questions...
    By motohead in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-29-2009, 11:12 AM
  5. A few top swap Questions
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:49 PM
