Thread: e85 swap questions
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 67
  1. #1 e85 swap questions
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    Hi, so i have a 1997 GTP, and i have heard that switching to e85 is good for a few pulley size drops and good increase in HP.
    what do i need to do to swap? I have read that several people have just stuck the 42# injectors in the cars without a tune. Since the increase in flow from the new injectors and the increase in fuel needed for e85 is the same you dont need the tuen. I would have thought this would require a tune to account for any small differences.
    any thougths?
    I have also seen several people ask about the fuel tank with e85 questions. What is the necessary fuel tank to run e85, and what comes in a 97gtp?
  2. #2 Re: e85 swap questions
    Feb 2009
    flintnasty MI
    My 97 works fine. The metal tank will be fine. Get ready to do fuel pump mods to keep up with the extra demand.
  3. #3 Re: e85 swap questions
    Sep 2014
    Richmond Virginia
    did you have to get it tuned? what injectors are you running?
    Thanks for the info about the pump and the tank.
  4. #4 Re: e85 swap questions
    Feb 2009
    flintnasty MI
    Stock tune. 3.2 pulley. Stock exhaust. 42.5# injectors.
  5. #5 Re: e85 swap questions
    Dec 2010
    DMV
    Damn, no tuning at all? Well let's see how my e85 Conversion goes.
  6. #6 Re: e85 swap questions
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    No, if you do 42.5 lb injectors, you don't need a tune. The pcm doesn't know you put 30% bigger injectors in, so it injects 30% more fuel. Which is what you need for e85. If you don't do 42.5 lb injectors, you need a tune.
    04 GTP -HAI, 1.9 rockers.
  7. #7 Re: e85 swap questions
    Dec 2010
    DMV
    Good to know. Any precautions to be aware of? And sorry for thread jacking op
  8. #8 Re: e85 swap questions
    Aug 2013
    Sandy, UT
    Less mpg? Moar tire spinning? thats about it. lol
  9. #9 Re: e85 swap questions
    Dec 2010
    DMV
    Lol thanks man. I'm going to do this next month after I pay some bills.
  10. #10 Re: e85 swap questions
    Mar 2014
    Tucson
    This just moved to the top of my mod list! With a walbro 255 already in the tank, I should be good to go.
    On the hunt for a good set of used 42.5# injectors!
  11. #11 Re: e85 swap questions
    May 2012
    Where winter never ends
    E85 is amazing.
    2000 Regal - Winter Beater
  12. #12 Re: e85 swap questions
    Mar 2014
    Tucson
    Short story;
    When we lived in Michigan, I burned corn to heat our house. That is, until the government started subsidizing e85 and the price of corn TRIPLED!! I hated the whole e85 thing.
    If it's as great as everyone says it is, I might change my mind...
  13. #13 Re: e85 swap questions
    You could always drive a prius.......... That would leave more gas for the rest of us.
  14. #14 Re: e85 swap questions
    Mar 2014
    Tucson
    Quote Originally Posted by 98ChainStretcher View Post
    Haha! I could not drive a prius.
    Quote Originally Posted by adecker View Post
    LOL! There is no if in that statement. Its amazing. End of story.
    Can't wait!
  15. #15 Re: e85 swap questions
    Arizona
    Quote Originally Posted by BrandonHall10 View Post
    Can't wait!
    And you can always come down here, I have HP tuners so I can get you setup on corn, theee s a lot of places in tuscon that sell e85 too
  16. #16 Re: e85 swap questions
    Mar 2014
    Tucson
    Quote Originally Posted by 91parkave View Post
    I live less than 4 miles and 8 minutes from the nearest e85 station. I'm going to have to do the conversion soon!
    I was thinking of doing the 42.5 injectors so I didn't have to tune right away. Do the injector swap, and a pulley drop. Run that for a while to save up for my own tuner. I will probably hit you up for some tuning advice once I get there though.
  17. #17 Re: e85 swap questions
    Sep 2014
    Richmond Virginia
    Thats my plan, maybe headers, and then work on my handling (swaybars etc) until i get my taxes back and go turbo .
    there's only one e85 station here close to my house, but the owner is running it in his car
  18. #18 Re: e85 swap questions
    May 2012
  19. #19 Re: e85 swap questions
    May 2012
    It all makes sense from a chemical standpoint... go get rubbing alcohol and put some on the back of your hand... blow on it...tell me what you feel... same thing in a cylinder...
  20. #20 Re: e85 swap questions
    1 station is all you need. Ive only got 1 station that sells E85 inside the DC metro beltway and its worth the hassle to go get it. I usually just go get it at night like 9pm when I need. The gains are certainly worth it. Unless you live in a metro area I doubt having only 1 station would be an issue.
  1. Swap questions
    By Bluemagic in forum General Grand Prix Discussion
    Last Post: 05-17-2013, 08:38 AM
  2. Top swap questions
    By killer84 in forum General Tech Discussion
    Last Post: 12-17-2010, 08:28 PM
  3. Some top swap questions
    By Traeger2591 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-23-2009, 07:45 PM
  4. Swap questions...
    By motohead in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-29-2009, 11:12 AM
  5. A few top swap Questions
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:49 PM
