Thread: wiring problem
Results 1 to 13 of 13
  1. #1 wiring problem
    Jan 2014
    virginia
    Help somebody.
    i have a serious wiring problem . there is a short somewhere and i can't find it. the battery is going down overnight. this is what i have tried so far. i dis-connected the fuze box, still didn't work, took every fuze out and every breaker out one at a time and still shorted. dis connected the alternator, still shorted. disconnected the starter,still there. disconnected the fuel pump stll did not help. changed the battery no help. the only thing left is the ignition to disconnect will do that tomorrow. anyone have any suggestions. i have run out of options. need some help.this is a 2000 grand prix with a 03 uni body on it. help me please!!!
  2. #2 Re: wiring problem
    Aug 2013
    Kitchener, Ontario
    Sometimes it's about getting down to the basics. Have you had the battery tested? In some cases, it's the battery itself not keeping the charge. Not trying to offend if you've already tested it
  3. #3 Re: wiring problem
    Jan 2014
    virginia
    i put a new battery in it from a friend and still archs but thank you for the reply so much
  4. #4 Re: wiring problem
    chances are you dont have a short. more then likely something is drawing power after the car is turned off. like a after market radio, amp, and so on.
  5. #5 Re: wiring problem
    Jan 2014
    virginia
    only has a stock radio in it. changed out the battery to see it that was it. no help there. probably a stock radio would not run down avernight. i did unplug the radio and still had an arch at the battery. i just about ran out of what to look for
  6. #6 Re: wiring problem
    whats with all this arc from the battery talk? its always gonna arc when you reconnect the battery.
    go to a parts store and have them test your battery and alt. or use a multi meter. you want to see 12 volts off the battery car off. up to 14 volts car running at a idle.
  7. #7 Re: wiring problem
    Jan 2014
    virginia
    i know what you are saying. i put a test light between the battery and the post. whatever it is runs the battery down overnight. so something got to be hot somewhere with the car off. put a new battery in it. disconnected the alternator completely and still power . disconnected the main hot wire going to the fuze box and still hot. disconnected the starter and still hot. don't know what else to do. got any ideas?
  8. #8 Re: wiring problem
    what i would do is put everything back on. then with the car off, key off. pull every last fuse to see if one is hot, thats not supposed to be. your gonna find a few that are hot full time. its normal. like the radios back up power to keep memory.
    also if you leave a phone charger, radar detector, xm unit, and so on plugged in over night it can wear on the battery too. if its one of the chargers with the red light that shows its got power, plugged in to the phone or other device or not, its a draw on the battery.
  9. #9 Re: wiring problem
    Jan 2014
    virginia
    i did all that. i am at my wits end with it. i even pulled the circuit breakers. its pulling a lot of power to run the battery down overnight with everything off. i really appreciate you shouting back at me though. don't know what else to try
  10. #10 Re: wiring problem
    what you need is someone who knows how to use a multimeter. with one of those tools in right hands you can figure it out.
  11. #11 Re: wiring problem
    Jan 2014
    virginia
    i think you are right. i really appreciate what you have tried to help me with. i am going to take it to someone that knows more about it ihan i do. hopefully a good mechanic can figure it out. thanks for all the advice scottydogg. don
  12. #12 Re: wiring problem
    Jun 2012
    Fort Collins
    I know I am a little late here, did you get it figured out yet? Curious when you were pulling your fuses, did you also pull the fuses under the hood in the engine compartment? Your main system fuses and relays are there which could be the likely culprits that would kill a battery overnight.
  13. #13 Re: wiring problem
    Jan 2014
    virginia
    I did pull the fuses and breakers that was just above the battery. i even dis- connected the fuse box under the hood there where the battery is. did not help. it is now at a friends garage. hopefully he can find the problem. may be there for a while as he also does insurance repairs. thanks for the shout back. all you guys out there are awsome for trying to help Don
  1. Need AMP wiring help!!!!!!! Now with another wire problem
    By dpzelenak in forum Audio, Security & Visual Electronics
    Last Post: 02-02-2013, 01:39 PM
  2. Amp Wiring Problem HELP!!!
    By ILoveAudi in forum Audio, Security & Visual Electronics
    Last Post: 08-18-2012, 11:07 PM
  3. Problem with transmission NO REVERSE...Any suggestions of problem
    By newmy1d in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-28-2012, 11:36 AM
  4. Wiring Problem
    By JoRoW99 in forum General Tech Discussion
    Last Post: 05-25-2012, 10:07 PM
  5. HUD wiring problem
    By thunder71173 in forum Audio, Security & Visual Electronics
    Last Post: 10-22-2010, 10:02 PM
