Thread: Need AMP wiring help!!!!!!! Now with another wire problem
Results 1 to 20 of 39
  1. #1 Need AMP wiring help!!!!!!! Now with another wire problem
    Alright im in the process of (re)installiing my subs and amp, and im hooking everything up but theres a wire that the shop that installed it the first time ran and i help with what its for and were can i put it, because i cant use the same spot they did.
    The wire comes out of the remote pot on the amp and was ran under the dash looks to be around the ignition system, its a thick brown wire. but i have no way of attaching the little wire coming off the amp to the thick wire in the car.
    So im looking for a new place to put it..
    Ill work on getting a link to the amp i got
    SMGPFC Member #10
  2. #2 Re: Need AMP wiring help!!!!!!!
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    connect to switched 12v source
    02 grand prix gt- L67 swap, ZZP 1.0 pcm, thrasher CAI, SLP 2.5 catback, A/C delete, 02 emulator, poly dog bone mounts, 6000k projectors with CCFL halos, 12 in slotted front rotors, ported blower and intake, evap and EGR deleted, 12" kicker cvr with 1000 watt amp, alpine cda 9886 deck
  3. #3 Re: Need AMP wiring help!!!!!!!
    CO5001 (500 Watts Max Power) - Orion Card Audio
    thats the amp
    and in the owners manual on the port layout it says this
    "REM Remote Turn-on Input - turns on/off the amplifier when fed Switched 9 - 15
    V+."
    so i guess i just to know where in the car can i tap into for this
    SMGPFC Member #10
  4. #4 Re: Need AMP wiring help!!!!!!!
    Quote Originally Posted by Erik Adam Rodriguez View Post
    Like a cig lighter port?
    SMGPFC Member #10
  5. #5 Re: Need AMP wiring help!!!!!!!
    Sep 2012
    bridgeport,NY
    no thats constant in these cars try the remote wire on the back of the deck it should be blue with a white line
  6. #6 Re: Need AMP wiring help!!!!!!!
    i have an aftermarket hu and theres a mess of wires behind it
    so basicly i just need to find a switched 12v source?
    Is there any in the trunk that can be used, that'll be easier then running it all the way up front. But if i have to then ill make do and try to find it. What is it used for? just telling the amp when to turn on?
    SMGPFC Member #10
  7. #7 Re: Need AMP wiring help!!!!!!!
    Sep 2012
    bridgeport,NY
    do you have bose in the car
  8. #8 Re: Need AMP wiring help!!!!!!!
    nope, but nothing is stock either. im gonna go look behind the hu and see if i can find the wire your talking about. if i cant ill take a pic and see if someone else can see it
    SMGPFC Member #10
    I live here. DirtDog's Avatar
    Jun 2012
    If its the switched 12 volt source u could connect it to radio power source or ignition source
    Sent from my DROID RAZR using Tapatalk 2
  10. #10 Re: Need AMP wiring help!!!!!!!
    Banned
    Jan 2013
    Colorado
    Yeah any ignition wire would be ideal to use. Nothing like that would be in the trunk.
  11. #11 Re: Need AMP wiring help!!!!!!!
    why dont you just solder a new length of wire to the existing wire, so it reaches the new amp location?
    Jun 2012
    ^^^^^^ That would be an even easier way to go about it
  13. #13 Re: Need AMP wiring help!!!!!!!
    the problem i have is that the wire they tapped into wont work with the wire i got now so i need to find a new source
    i pulled the hu and found this
    can i use that?
    SMGPFC Member #10
  14. #14 Re: Need AMP wiring help!!!!!!!
    Sep 2012
    bridgeport,NY
    thats it use that wire problem solved
  15. #15 Re: Need AMP wiring help!!!!!!!
    great thanks for the help, and heres to think i was starting to think i was getting this stereo stuff
    SMGPFC Member #10
  16. #16 Re: Need AMP wiring help!!!!!!!
    Alright so i have another,not problem but issue.. i have a 4gauge ground wire but i dont have any way to attach it to the body, so im looking for ideas
    i was thinking just screw it down and be done with it but idk how well that'll work, anybody got some ideas?
    SMGPFC Member #10
  17. #17 Re: Need AMP wiring help!!!!!!! Now with another wire problem
    drill a hole, nut and bolt that sucker down? sand the paint off first.
    or sand and use a fat self tapping screw to the trunk.
  18. #18 Re: Need AMP wiring help!!!!!!! Now with another wire problem
    Yoga city
    sand down around a strut bolt, works great and is good connection. dont do a self tapper, they will loose connection or not be a great ground. bolt is secured
  19. #19 Re: Need AMP wiring help!!!!!!! Now with another wire problem
    that strut bolt wont get any better. wish i thought of it lol
  20. #20 Re: Need AMP wiring help!!!!!!! Now with another wire problem
    how can i hook the wire to it i dont have any connectors, i would just have to wrap the wire around the nut and tighten it down
    SMGPFC Member #10
  1. led wiring help
    By dpzelenak in forum Audio, Security & Visual Electronics
    Last Post: 03-29-2011, 04:13 PM
  2. wiring help
    By DDPeppa in forum Audio, Security & Visual Electronics
    Last Post: 12-10-2010, 11:19 PM
  3. wiring help
    By grandprixxx94 in forum General Tech Discussion
    Last Post: 09-24-2010, 11:00 AM
  4. Wiring or???
    By GTPJOE90 in forum Audio, Security & Visual Electronics
    Last Post: 09-19-2009, 10:30 PM
  5. Wiring
    By gpgt in forum Audio, Security & Visual Electronics
    Last Post: 03-27-2009, 03:02 PM
