Thread: Antifreeze question
Results 1 to 20 of 21
  1. #1 Antifreeze question
    Apr 2013
    Union City, In
    i jus changed my lim gaskets. I drained my antifreeze, now when i went to refill it i was told it should take almost three gallons. I filled the rad with a gallon of antifreeze and when i was in the store i grabbed the wrong stuff meant to grab 50/50 but actually got conventional. so i was told by a mechanic i could dumb my gallon of water in the reserve area and it would mix its self. But the reserve isnt pulling any of the water into the rad when the car is running it hasnt went down much at all and i let it run for 3 to 5 minutes. My question is will it pull the water and mix without harming anything?
  2. #2 Re: Antifreeze question
    you can buy a antifreeze tester for cheap, it will tell you if theres to much or to little antifreeze.
    or pull the lower hose and let some drain out, top off with water.
    the over flow will take the water and mix it with the rest, but the car has to get hot/ up to temp, and then cool down on its own with out touching the caps.
  3. #3 Re: Antifreeze question
    Apr 2013
    Union City, In
    ok so i jus let it run longer to mix is what yoyur saying?
  4. #4 Re: Antifreeze question
    pretty much, as it heats up it pushes some out, as it cools off it sucks it back in, as long as your rad cap, lines/hoses and overflow tank cap are all tight that is.
  5. #5 Re: Antifreeze question
    Feb 2013
    37.295091, -121.930053
    you do know that any car out there can run pure water with little problem right? if your mix is off a bit i wouldn't worry to much about it. If your running pure water and you live were the snow falls every years best to have more antifreeze then to little.
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  6. #6 Re: Antifreeze question
    Apr 2013
    Union City, In
    Thanks for the help!!!!
  7. #7 Re: Antifreeze question
    you dont want to run pure water for long, pure water will let the inside of the block rust, where antifreeze adds rust protection and keeps from freezing. as well as boils at a higher temp (380 deg) where water boils @ 212.
    antifreeze is your best friend where ever you live.
  8. #8 Re: Antifreeze question
    Dec 2012
    Where 4T65E's were born
    It also lubricates the seal and bearings in the water pump, right?
    Sold.
  9. #9 Re: Antifreeze question
    Feb 2013
    yep
  10. #10 Re: Antifreeze question
    Jan 2013
    Tolono IL
    Does it have to be dexcool coolant?
  11. #11 Re: Antifreeze question
    SWPA
    No. Dexcool is crap.
  12. #12 Re: Antifreeze question
    Jan 2013
    Tolono IL
    Thats what I heard and it's clogging up my radiator. Gonna drain it all out soon but didn't know what coolant it can take
  13. #13 Re: Antifreeze question
    SWPA
    Drain it, flush it, fill it with cheap green stuff.
  14. #14 Re: Antifreeze question
    Jan 2013
    Tolono IL
    Sounds good lol thanks
  15. #15 Re: Antifreeze question
    Aug 2013
    Kitchener, Ontario
    I've always been under the impression that a mixture that is more water will cause rest and blockages within the rad. But in the past I've been told that antifreeze has a lower boiling point then water, that's why antifreeze needed to be mixed with water (or already premixed).
    Correct me if I am wrong.
  16. #16 Re: Antifreeze question
    Quote Originally Posted by Phlip77 View Post
    google it, properly mixed antifreeze boils at 380 deg. we all know water boils a 212.
    now straight antifreeze boils before water would. but your not supposed to run straight antifreeze, its to be mixed. either you mix it, or buy pre mixed, but pre mixed is a waste of money.
  17. #17 Re: Antifreeze question
    Aug 2013
    Kitchener, Ontario
    Very interesting. I knew about the not to run straight water or run straight antifreeze. The only confusing thing here is if straight water boils at higher temp than straight antifreeze. How does a diluted solution of both bring the boiling point higher. I'm not disagreeing with you just trying to wrap my head around it, that's all.
  18. #18 Re: Antifreeze question
    science my friend... science.
    some smarter then us both people figured this all out decades ago.
    as you may know your not supposed to run antifreeze at most drag strips, as well as nascar and such. antifreeze is pretty slick it it hits the track, so they use another additive that just raises the boiling point of the water.
  19. #19 Re: Antifreeze question
    Aug 2013
    Kitchener, Ontario
    Learning new stuff everyday. Thanks
  20. #20 Re: Antifreeze question
    SWPA
    The other thing that has to do with raising the boiling point is the pressure the rad cap lets the system hold in. There are some guys in the 3s world that run highly modified cars and live in the desert heat. The stock 3s cap holds 13 psi if I remember right. One of them discovered a TRD rad cap that holds 18 psi (?) fit perfectly and it helped keep temperatures down.
  1. oil in antifreeze
    By lorello in forum General Grand Prix Discussion
    Last Post: 06-19-2012, 09:55 AM
  2. Oil In Antifreeze
    By zackp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-13-2012, 01:34 AM
  3. antifreeze leak question
    By gentrymartin in forum General Tech Discussion
    Last Post: 03-12-2012, 02:37 PM
  4. antifreeze leak
    By dirtdriver11 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-29-2011, 08:50 AM
  5. Idk, antifreeze?
    By Tha Ghost in forum General Tech Discussion
    Last Post: 01-30-2011, 09:49 PM
