Thread: Engine Cleaning
Results 1 to 15 of 15
  1. #1 Engine Cleaning
    Oct 2012
    Beacon, NY
    What's a good way to clean an engine, cosmetically? I have a lot of oil on my engine, the normal built up dirt and I just want to make it look clean.
    GXP Level Member Kolton Lock's Avatar
    Mar 2012
    Minneapolis MN
    The search bar up top works if you use it
    But the general consensus is: cover up electronics and aftermarket air filter(if that applies), then throw on a bunch of engine degreaser, but regular degreaser works too. Finally you just take a hose and spray it all down.
    If I recal correctly, you can use something like Armor All tire shine to give it a ton more shine.
    EDIT: some minor searching gave me this
    http://www.grandprixforums.net/showthread.php?t=47930
    Good luck
  3. #3 Re: Engine Cleaning
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    I've had good luck with purple power, although I hear it is bad for paint if you overspray it.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  4. #4 Re: Engine Cleaning
    GTP Level Member Lishap's Avatar
    Jan 2012
    New York
    ^^agreed purple power works great and its fairly cheap.
  5. #5 Re: Engine Cleaning
    i used crc engine de greaser last time i cleaned up. it had no smell after it was washed off with a hose. and worked as good if not better then the rest out there.
    you want to put the car on car ramps, or jack stands so you can spray under the car, so you can hit the sides of the engine block and pan, and the back side of the tranny. from the pass wheel area, you can spray a good chunk of the trans down too. then spray the top of the engine down, 2 cans is always a must, as one can will do it one time, if its real bad, spray it down again.
    if your all stock, air box and all, you can literally spray the whole engine down with a hose, just avoid nailing the alternator with a a full blast for to long.
    all the plugs and wires have weather pac seals, its all safe to get wet.
    if you have a open cone air filter, take it off, bag and rubber band the TB opening.
  6. #6 Re: Engine Cleaning
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Purple Power.
    But i think theres a sticky somewhere on this site for engine cleaning.
    Mar 2012
    Minneapolis MN
    Purple Power.
    Did the I give not work ?
  8. #8 Re: Engine Cleaning
    Pennsylvania
    Purple stuff, green stuff, someone had luck with the dollar store stuff, whatever. scrub stuff clean with a paintbrush. rinse and repeat as necessary. Then tire shine the plastic and rubber and wipe it dry with a cloth.
  9. #9 Re: Engine Cleaning
    tire shine looks good for a few weeks, then dirt and dust stick to everything, and make it look all dirty again, yes i tried it out, not a fan at all.
  10. #10 Re: Engine Cleaning
    Pennsylvania
    You didn't wipe it off enough, I guess. I use it plenty, get compliments months after a cleaning.
  11. #11 Re: Engine Cleaning
    antioch ill
    simple green get s soft brush scrub then wash what you cleaned and repeat
  12. #12 Re: Engine Cleaning
    My hood stays closed.
  13. #13 Re: Engine Cleaning
    Oct 2012
    Beacon, NY
    Thanks guys. I can't use the search bar on my phone, it doesn't work for some reason.
    Mar 2012
    Minneapolis MN
    If you have an android or iphone I highly recommend the app Tapatalk.
    Its a few bucks but it makes this forum pretty convenient
  15. #15 Re: Engine Cleaning
    Try the ez off outdoor grill cleaner. Stuff is amazing, better than all the engine degreasers I have tried.
  1. cleaning the engine..
    By Mikey Bonefas in forum General Tech Discussion
    Last Post: 07-25-2012, 01:48 PM
  2. engine cleaning
    By busagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-17-2010, 08:53 PM
  3. cleaning engine??
    By kjohnson in forum Visual/Body Modifications
    Last Post: 11-19-2009, 07:39 AM
  4. Cleaning up the engine bay
    By SLO-6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-12-2008, 07:22 PM
  5. Engine Cleaning
    By wrfdff4 in forum Visual/Body Modifications
    Last Post: 03-19-2008, 09:04 PM
