Thread: Engine Cleaning
Results 1 to 17 of 17
  1. #1 Engine Cleaning
    Erie, PA
    I NEED to clean my engine i saw the link to autopia (very useful) but im not sure what engine parts i need to cover for my 99 gt. If anyone has a link with a step-by-step process for a GP GT let me know
    Thanks,
    Bobby
  2. #2 Re: Engine Cleaning
    Oklahoma
    I'll tell you what I do.
    I remove my hood heat shield thing (I dont know the actual term for it)
    I cover up my open cone air filter with the large gallon sized zip lock bags
    I then stick about $5 in the car wash and go to tow on the engine bay and under carriage. People laugh, but its not uncommon to see me nearly flat on my belly spraying down the underside of the whole car, including the engine bay.
    I rinse everything down, remove the air filter cover, re-install the heat shield thingy and once everything has dried out really well I wipe everything I can with a rag and Pledge dusting polish. Pledge does a MUCH better job because it does not attract dust like Armor All does. I wipe down all the rubber hoses, vacuum lines, braces, everything I can including CV boots inner and outer.
    Im not quite as fanatical as those the put their cars in car shows all the time but Im not far behind.
  3. #3 Re: Engine Cleaning
    Hoffman/Schaumburg, IL
    i keep seeing this question, maybe someone should do a write-up...(hint hint^^^^)
  4. #4 Re: Engine Cleaning
    Oklahoma
    LOL. Yeah, perhaps I should do that. But right now it would have to wait until I get the tranny replaced and the car off jack stands.
  5. #5 Re: Engine Cleaning
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    I have a questions about this, since I've been showered by a salt truck, I would lve to have a clean engine bay.
    So you don't have to cover the alternator or PCM? Would the long term effects of hosing down a electronic engine mgmt car, be massive electrical problems much later?
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  6. #6 Re: Engine Cleaning
    Fort Wayne, IN
    Something I learned about engine cleaning on a car with Headers.... DONT repeatedly wash it off without letting things dry out or hot! My cousin has SLP headers on his car and always rinses off the engine and after just months rust spots started under the coating. A local performance coating place said it was from the minerals in the water being baked into the poors of the coating and speeding up oxidizing which causes the rust.
  7. #7 Re: Engine Cleaning
    GT Level Member Going Too Phast's Avatar
    Quote Originally Posted by IndeedSS View Post
    I've always heard to cover the alternator and coils, but some people don't. If the PCM is exposed it won't hurt to cover it. Aluminum foil works well. There is no harm is washing the engine compartment, if it couldn't take a little water we'd all be in trouble. That is why there are weatherpack connectors under there. That said though use common sense. Don't spray with high pressure and try to avoid electrical components (which is kinda hard with modern cars).
    .: 1998 GTP : 3.5 : PT : 1.9s : Intake : DP : Plog : 180* : 605s : UD WPP : STBs : 12" Brakes :.
  8. #8 Re: Engine Cleaning
    the first few times I washed it with a pressure washer and degreaser, and no problems from that, Carmax steam cleans all the engine bays, and that seems to be ok..... but do what you feel comfortable with, if it makes you feel better to cover those components, by all means cover em
  9. #9 Re: Engine Cleaning
    Banned
    New Port Richey Florida
    when i d mine i cover the alt coils and tb and use purple poer for de greaser it works good
  10. #10 Re: Engine Cleaning
    GTP Level Member David99GTP's Avatar
    Florida
    Carefull of the purple stuff on Aluminum. Some brands have a warning on the back label not to use on Alkaline sensitive metals such as aluminum. I use simple green, a toothbrush, and Low pressure water. Your car gets wet in the rain right? Just use good sense and go for it. A clean engine runs cooler and a clean engine makes any future issues fast and easy to spot.
    1999 GTP
    2002 Chevy 2500HD lifted on 36" Swampers
    http://www.cardomain.com/ride/2619487
  11. #11 Re: Engine Cleaning
    Saraland Alabama
    best cleaner for engines is brake cleaner (used to use it before paint)
  12. #12 Re: Engine Cleaning
    St Louis MO
    What I've noticed when curious about how much water gets in the engine bay after driving in heavy rain is that there isn't nearly as much as I thought there might be. Perhaps it's because the heat causes it to evaporate pretty quickly.
    I would love to be able to put the hose to the engine compartment, but I'm literally terrified to do so.
    Interesting info about the header coating.
    2010 Camaro SS LS3
  13. #13 Re: Engine Cleaning
    Florida
    Quote Originally Posted by archemedes View Post
    Works well on hard to reach spots. Not nice to panted surfaces but does blast grease away well. Cheap too.
    1999 GTP
  14. #14 Re: Engine Cleaning
    Saraland Alabama
    on my old carbed cars I just leave the engine running when I spray it with water
  15. #15 Re: Engine Cleaning
    Here is pretty good article about cleaning an engine.
    Engine Detailing (Clean, Degrease, Protect) | How-to Guide
  16. #16 Re: Engine Cleaning
    SE Level Member WillOverkill's Avatar
    Feb 2008
    Amazing Roll-Off is a fabulous degreasing product to use to clean the engine with. Doesn't dull painted surfaces, actually brightens aluminum.
    A tip for light cleaning is spray down with GM class cleaner, the aerosol cans. Once it foams up, blow dry it clean with compressed air.
    I use quick detailer so there's no glossy finish, but I'll have to try the pledge tip!
    Get Your 3800 Overkilled @ http://www.getoverkilled.ca
  17. #17 Re: Engine Cleaning
    Barksdale AFB, LA
    I use an Oreilly brand engine degreaser. Bag off the PCM, air filter, alternator, and coils (well, now with the WizAired just the alt and coils) and hose it off. Start up and watch it steam it all away (kinda spooky).
    I noticed how much water gets up under then with all the water spots that keep getting on my WizAired window.
    At the engine detailing how to...
    If you have compressed air available, this is the best way to remove old leaves, dead cats and such.
    LOL!
    2009 Subaru Impreza WRX STI
  1. New Engine Bay Pics
    By GTP SE in forum Visual/Body Modifications
    Last Post: 05-21-2008, 08:01 AM
  2. Which engine oil?
    By Deezul_AwT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-11-2008, 04:41 PM
  3. Service Engine??
    By wrfdff4 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-18-2008, 11:55 AM
  4. NEW use for an engine hoist!!!!
    By Trannyman95 in forum Off Topic Discussion
    Last Post: 02-08-2008, 11:51 PM
  5. Another interesting Engine
    Last Post: 02-03-2008, 07:55 PM
