Thread: cleaning engine??
Results 1 to 20 of 22
kjohnson cleaning engine?? 11-09-2009, 09:24 PM
josemolina2008 Re: cleaning engine?? 11-09-2009, 09:46 PM
kjohnson Re: cleaning engine?? 11-09-2009, 10:49 PM
2000GTP Re: cleaning engine?? 11-11-2009, 01:02 AM
SeanGTP Re: cleaning engine?? 11-11-2009, 02:56 PM
DDPeppa Re: cleaning engine?? 11-12-2009, 08:36 PM
TheOtherNick Re: cleaning engine?? 11-12-2009, 08:45 PM
BlownBigBlock Re: cleaning engine?? 11-12-2009, 09:42 PM
kjohnson Re: cleaning engine?? 11-12-2009, 11:07 PM
2000GTP Re: cleaning engine?? 11-15-2009, 03:36 PM
TorqueAutoMotiv Re: cleaning engine?? 11-15-2009, 03:46 PM
kjohnson Re: cleaning engine?? 11-15-2009, 04:08 PM
TorqueAutoMotiv Re: cleaning engine?? 11-15-2009, 05:39 PM
gpgo Re: cleaning engine?? 11-15-2009, 05:53 PM
SnowDrift Re: cleaning engine?? 11-18-2009, 12:41 PM
Sandman Re: cleaning engine?? 11-15-2009, 07:51 PM
Pittman06 Re: cleaning engine?? 11-15-2009, 09:30 PM
TorqueAutoMotiv Re: cleaning engine?? 11-15-2009, 11:38 PM
Pittman06 Re: cleaning engine?? 11-18-2009, 12:54 PM
SnowDrift Re: cleaning engine?? 11-18-2009, 02:35 PM
Pittman06 Re: cleaning engine?? 11-18-2009, 03:24 PM
SnowDrift Re: cleaning engine?? 11-19-2009, 07:39 AM
  1. #1 cleaning engine??
    GTX Level Member kjohnson's Avatar
    Nov 2008
    Harlan, IA and University of Northern Iowa
    over thanks giving break im going to be replacing a bunch of seals on my car and I was wondering what i could use to clean the engine compartment. any ideas would be much appreciated
    silver 2003 Grand Prix GT List is on it's way to be updated
  2. #2 Re: cleaning engine??
    GT Level Member josemolina2008's Avatar
    Modesto, Ca.
    Well I've heard that you can spray all purpose cleaner on the engine and then hose it off, I haven't tryed it because I'm a little scare to do it.
    GP is gone...
  3. #3 Re: cleaning engine??
    Nov 2008
    ive heard of tire foam and then spraying it off too but i dont want to mess anything up especially since ill be doing that right after i fix it and id like it to stay fixed for awhile after that.
  4. #4 Re: cleaning engine??
    Aug 2008
    Long Island, New York
    you cover up some stuff, battery, alternator, air box. maybe coils. hose it down, spray some degreaser all over it, scrub a little. and hose it off good
  5. #5 Re: cleaning engine??
    Nov 2008
    Waterloo, Iowa
    I would spray some purple power on some stuff and clean it off with the power washer. As long as you're not blasting the battery or the fuse box, you should be pretty good. A little water doesn't hurt usually, especially consider when doing an automatic car-wash they usually spray up from the ground as you enter and hit a lot of that stuff anyway. Just don't directly spray it down and you'll be good.
  6. #6 Re: cleaning engine??
    Canada
    so cover up battery, fuse box, alternator, and intake... dont worry about wires?... and hose it off or high-ish pressure wash?
  7. #7 Re: cleaning engine??
    Charles City, IA
    Just use a garden hose not a power washer.
    SMGPFC Two Nipple General
  8. #8 Re: cleaning engine??
    GTP Level Member BlownBigBlock's Avatar
    Apr 2009
    Carlisle PA
    Simple green here, I guess Purple power would work too...
  9. #9 Re: cleaning engine??
    Nov 2008
    ok cool ill have to give it a shot. thanks guys
  10. #10 Re: cleaning engine??
    Aug 2008
    Quote Originally Posted by kjohnson View Post
    yeah its a pretty easy job... let us know how it turns out
  11. #11 Re: cleaning engine??
    Apr 2009
    stockton ca
    Just a small warning about simple green I love the stuff but it doesnt like all metals and will leave some metal looking oxidised
  12. #12 Re: cleaning engine??
    Nov 2008
    any of em in the engine bay or is this just a general comment?
  13. #13 Re: cleaning engine??
    Apr 2009
    stockton ca
    certain metals Honestly once i found this out i stopped using it as an all over cleaner so i cant tell you im guessing cast aluminum cause its poruos to begin with but not sure
  14. #14 Re: cleaning engine??
    Donating Users
    central ohio
    i went to car wash and sprayed engine with the tire cleaner and then rinsed it off on the gentle cycle, looks good didnt cover anything, i do have supercharger cover off. just dont hold over alt and wires for very long. its a 98 gtp.
  15. #15 Re: cleaning engine??
    GTP Level Member SnowDrift's Avatar
    Apr 2009
    Central Ohio map dot.
    Quote Originally Posted by gpgo View Post
    X2
    Just did this. I just opened the hood and sprayed everything using our gas powered pressure washer we have at the shop. I didn't cover anything. I cleaned off the battery and coils, too. The only thing I didn't do was blow it into the alternator and I went quickly over the coils. I started it up right afterward to let it warm up and that's all.
    Just do it on a cool engine
  16. #16 Re: cleaning engine??
    Jan 2009
    Tallahassee, FL
    I do it the hard way then, 409 and paper towels are fine with me. Takes a little longer but I'm pretty OCD with my car sometimes. A good way to keep some of the plastics looking clean is to wipe them down with WD-40, makes them look new for a while.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  17. #17 Re: cleaning engine??
    Wooster, Ohio
    my normal way is to spray it down (find Castrol Super Clean, THE BEST!!!) with degreaser and let it set, soft brush and tooth brush for everything else, just watch the hose on your electronics, other then that you'll be fine. On my S-10 i spray the entire engine and alt and everything with Super Clean and use a hose on it once a month, and in 70k miles i've never had a single issue, just my 2 cents
  18. #18 Re: cleaning engine??
    Apr 2009
    stockton ca
    The last time i actually fully detailed an engine bay was my friends mustang a magicball mini tooth brush some pipe cleaners a bottle brush simplegreen blackmagic and a round 4 hours time
    made me 100 bucks though so no real complaints It get insane when you do it right
  19. #19 Re: cleaning engine??
    Wooster, Ohio
    where are you from in ohio Snowdrift? I know you said in another thread your an hour and half from Summit
  20. #20 Re: cleaning engine??
    Apr 2009
    Quote Originally Posted by Pittman06 View Post
    We're east of Marion. You're not far from us. I frequent Fin, Feather and Fur, near Ashland, as much as possible
  1. Cleaning up the engine bay
    By Clar2478 in forum Visual/Body Modifications
    Last Post: 03-23-2009, 01:44 AM
  2. Cleaning up the engine bay
    By SLO-6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-12-2008, 07:22 PM
  3. Cleaning up engine
    By 2000GTP in forum Visual/Body Modifications
    Last Post: 09-25-2008, 03:26 PM
  4. Cleaning Engine Bay
    By stlmo_gtp in forum Visual/Body Modifications
    Last Post: 08-19-2008, 01:42 AM
  5. Engine Cleaning
    By wrfdff4 in forum Visual/Body Modifications
    Last Post: 03-19-2008, 09:04 PM
