The search bar up top works if you use it
But the general consensus is: cover up electronics and aftermarket air filter(if that applies), then throw on a bunch of engine degreaser, but regular degreaser works too. Finally you just take a hose and spray it all down.
If I recal correctly, you can use something like Armor All tire shine to give it a ton more shine.
EDIT: some minor searching gave me this
http://www.grandprixforums.net/showthread.php?t=47930
Good luck![]()
