Thread: Top Swap Problem
Page 2 of 2 FirstFirst 12
Results 21 to 40 of 40
  1. #1 Re: Top Swap Problem
    GTP needs to run a 3.2 or smaller pulley to run out of injectors...
    Generally smaller.
  2. #2 Re: Top Swap Problem
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Generally smaller.
    He is top swapped....Or you you just reconfirming the point?
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  3. #3 Re: Top Swap Problem
    Grand Island, Nebraska
    3.2 with no headers...most people say you need headers just to run a stock pulley on a top swap. at least a downpipe w/ the u-bend delete. j/w but what did you do with the MAP sensor?
  4. #4 Re: Top Swap Problem
    SE Level Member whitetyler1991's Avatar
    New Milford, Pennsylvania
    I did the top swap myself, every sensor is hooked up, everything thats suppose to be. no check engine light, nothin. and the reason I haven't experienced any KR is because the car hasn't allowed itself to run on any real amount of boost, yet. as of right now I drive the car back and forth to college and it runs great, just putting around though. I just ordered a 3.4 pulley, slp longtubes, and I'm looking into an intercooler to pick up in the near future.
  5. #5 Re: Top Swap Problem
    long tubes? since when?
    every design is a short tube....
  6. #6 Re: Top Swap Problem
    Hagerstown,Md
    WOw you dont even have headers and you were on a 3.2....Good thing you came to your sense's. Your not going to be able to run under a 3.8 without headers.
  7. #7 Re: Top Swap Problem
    Meh, it all depends on how you're flowing, and how much of a safety net you want.
  8. #8 Re: Top Swap Problem
    Hagerstown,Md
    Top swaped cars require more fuel per pulley. You need injectors on 3.5 or lower. 3.25 isnt possible. There is no safty net on l67 injectors on a 3.25
  9. #9 Re: Top Swap Problem
    Anything high compression NEEDS headers...it isn't a want. Plus, the point of having high compression is not utilizing all the boost a low comp motor needs to go just as fast. BUT...it is way more prone to knock...so keep that in mind
  10. #10 Re: Top Swap Problem
    3.5 seems a tad extreme, but it doesnt bother me. Already have 42.5's... figured I'd just buy injectors once.
  11. #11 Re: Top Swap Problem
    Hagerstown,Md
    Goes back to the .3 pulley differance. Ask any top swapper what there IDC is on a 3.5. Its in the 90's. On a 3.4 im at 98-101 percent
  12. #12 Re: Top Swap Problem
    yeah correction, not long tubes my buddy order slp long tubes for his camaro from a local shop when I ordered mine, but yeah I'm waitin on some slp's and a 3.4 pulley. I would have gotten all of this at the same time of the swap but its all about money, I'm in college so I have to make sure I have enough money to live. but yeah 3.4 and headers on the way, stock injectors for the time being
  13. #13 Re: Top Swap Problem
    Kansas
    Youll be fine on the stock injectors with the 3.4
    SOLD 1999 GT Silvermist TS
  14. #14 Re: Top Swap Problem
    Hagerstown,Md
    No he wont. I run over 100 percent injector duty cycle on l67's on a lean intercooled setup......BUT WHAT DO I KNOW. Ive only been running a 3.4 topswapped for 1 year and been topswapped for 4 years. Further more a 3.4 you should also have a Pump rewire. http://www.streetfire.net/video/2001...ynp_208097.htm
    I back up everything I say with fact's http://www.scandepot.net/viewscan.php?pk=5267 Heres my scan, please note Injector duty Cycle. Anything over 85 percent you should really upgrade. FWIW. 100 percent the injector doesnt pulse and fuel gets superheated
  15. #15 Re: Top Swap Problem
    Akron Ohio
    Quote Originally Posted by 01gpgt01 View Post
    No he wont. I run over 100 percent injector duty cycle on l67's on a lean intercooled setup......BUT WHAT DO I KNOW. Ive only been running a 3.4 topswapped for 1 year and been topswapped for 4 years. Further more a 3.4 you should also have a Pump rewire. 2001 grand prix GT DYNP - Car Videos on StreetFire
    I back up everything I say with fact's NannyLog(01.02.2000_19.01.09). from GPGT01 -- Scan Depot dot net Heres my scan, please note Injector duty Cycle. Anything over 85 percent you should really upgrade. FWIW. 100 percent the injector doesnt pulse and fuel gets superheated
    Quoted for truth.
  16. #16 Re: Top Swap Problem
    Kansas
    I stand corrected.. Good to know.. Doesnt matter im getting my 60s on soon.
  17. #17 Re: Top Swap Problem
    Hoffman/Schaumburg, IL
    3.2 is way too small, with headers, 3" catback, full intake and tune, I would still get some KR on a 3.8, one of the big problems is the GT Fuel Pump, I didn't think It was an issue until another local had a ton of KR problems until he found out his GTP had a GT pump... once a GTP pump was put in, most the KR disappeared.........
    Throw a 3.5 or 3.6 on there, and see if it runs better, also Scan, Scan, Scan that, we had a local with a ZZP dyno tune that the fuel cut off was set below the shift point, everytime he would hit 5500rpm, 7* KR and Lean spike
  18. #18 Re: Top Swap Problem
    Hagerstown,Md
    Quote Originally Posted by 02BlueGT View Post
    The GT pump is a one speed pump with SIGHTLY less output. I installed a gtp pump in mine with a rewire. I had pump drop off on a 3.5 pulley on a stock GT pump with no rewire
    02GT what fuel pump are you running. Im getting 65's and going e85 3.25 pulley on mine.
  19. #19 Re: Top Swap Problem
    The first problem is being able to run a 3.4 pulley on a top swap in the first place.
    That requires SOMETHING above and beyond headers...
  20. #20 Re: Top Swap Problem
    Donating Users kfish's Avatar
    Ohio
    i also was maxed out on my 3.5 with headers. I needed to go to 43s to run a 3.4
  1. i might top swap
    By nascartech in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-02-2010, 12:15 AM
  2. M90 Kit vs. Top Swap?
    By Traeger2591 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-26-2009, 10:27 PM
  3. 2000 4T65E HD tranny in a 1998 GTP with no problem in swap......but!!
    By daytonapacecarguy in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-04-2009, 10:53 AM
  4. Top Swap Re Flash problem
    By MNGP07 in forum PCM Tuning
    Last Post: 03-22-2009, 08:02 PM
  5. What wil i need to do a top swap
    By gp3800t in forum General Tech Discussion
    Last Post: 02-22-2009, 03:06 PM
