The reason a pulley would be too much is too much heat caused by the compression from being an NA lower end and spinning of the charger. This equates to knock. If you have no knock..then you have something off in your tune. However experience tells us that your pulley and other mods are too much for that setup and having no knock would be a miracle. it's simply something that doesn't happen unless there's no timing in the tune.
