Thread: Top Swap Problem
Results 1 to 20 of 40
  1. #1 Re: Top Swap Problem
    SE Level Member whitetyler1991's Avatar
    New Milford, Pennsylvania
    I also may have a different set up when it comes to my pulleys, at the time of the build the only idler pulleys and top half of the pulley set up by the coil bracket I had access to was off a supercharged Regal I believe. I'm not sure if that makes much of a difference, because I don't know the specs the car is running on around 10-12 lbs of boost
  2. #2 Re: Top Swap Problem
    Regal and GP are identical for pullies. The items being mentioned are all possibile. Sounds like you haven't scanned to monitor KR.
  3. #3 Re: Top Swap Problem
    I live here. TLSheff's Avatar
    Quote Originally Posted by whitetyler1991 View Post
    at the moment no I don't have headers. the car runs great, better than it ever has, until any boost gets built up then it cuts out, acts like its starving for fuel or something.
    as far as I know theres absolutely know KR, I might try a bigger puller to see if it makes any difference. The PCM I called them for and talked them through the whole process to make sure it was exactly what I needed, I just recieved it yesterday hoping it would solve the problem, it made the car run way better but it hasn't solved my boost problem.
    Given its running BETTER with the tune... jump up to a 3.4 pulley & get some header immediately... make sure its got a 3" downpipe... your prolly getting too much backpressure for the boost your pushing and i personally think your lucky you dont have a blown head gasket already, or worse
  1. i might top swap
    By nascartech in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-02-2010, 12:15 AM
  2. M90 Kit vs. Top Swap?
    By Traeger2591 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-26-2009, 10:27 PM
  3. 2000 4T65E HD tranny in a 1998 GTP with no problem in swap......but!!
    By daytonapacecarguy in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-04-2009, 10:53 AM
  4. Top Swap Re Flash problem
    By MNGP07 in forum PCM Tuning
    Last Post: 03-22-2009, 08:02 PM
  5. What wil i need to do a top swap
    By gp3800t in forum General Tech Discussion
    Last Post: 02-22-2009, 03:06 PM
