Thread: Rattlle noise
Results 1 to 12 of 12
  1. #1 Rattlle noise
    Baldwin Park
    Watz up everybody im new to this forums..and i got a problem with my 98 gtp its making this weird rattle coming from the belt side of the engine can somebody tell me what wrong with it
  2. #2 Re: Rattlle noise
    s/c coupler junk?
  3. #3 Re: Rattlle noise
    Baldwin Park
    I already got my whole s/c rebuilt and its still doing the loud rattle noise ...idk what it could be also my crank pulley is cracked idk if that is making the noise because i took off motor and s/c belts and turnd on the engine and still making the noise...hopefully you guys can help me out...
  4. #4 Re: Rattlle noise
    SE Level Member my98gtp's Avatar
    Lost in Mn.
    If the super charger was re-built it should'nt be the coupler, How is the belt tenioner on it ? My guess maybe thats where the rattle is ?
  5. #5 Re: Rattlle noise
    Florida
    Mine did the same too, it was the S/C Tensioner, it had worn out really bad, and was rattling to all hell.
    Listen down by the tire/in the wheel well, and see if it's down there, if so, its the crank.
  6. #6 Re: Rattlle noise
    Baldwin Park
    Ok ima check on that later on hopefully its the crank pulley..is the crank pulley expensive?? Also is it difficult to change the crank pulley
  7. #7 Re: Rattlle noise
    Its maybe 100 or less if you go used.
    You need special pulley puller bolts and a spacer which you can get from ZZP, not sure where else.
  8. #8 Re: Rattlle noise
    Florida
    It's kind of a pain to remove the pulley. You can get a puller from ZZP for fairly cheap, or rent one from a parts store. As far as a crank pulley price, cheapest would probably be from a parts store.
  9. #9 Re: Rattlle noise
    you still need the correct bolts and a spacer thats long enough to do the job.
  10. #10 Re: Rattlle noise
    Florida
    the kit I got from advance auto parts actually had the correct parts, and you can use a
    3" long 3/8's extension as the spacer, works like a charm
  11. #11 Re: Rattlle noise
    Baldwin Park
    There got my car running..it was the harmonic balancer that was messed up on my car now it runs great thanks for all your advice really came in handy
  12. #12 Re: Rattlle noise
    Kentucky
    My 2002 has a loose type rattle, but it quits if I turn the a/c on..,any ideas? All advice would be greatly appreciated.
  1. GTP Noise....
    By SuperCharged0nE in forum General Tech Discussion
    Last Post: 04-02-2010, 12:01 PM
  2. odd noise at 27 mph
    By rossscrappy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-06-2010, 06:01 PM
  3. New noise..again..help?
    By BwolfGT in forum General Tech Discussion
    Last Post: 11-03-2009, 09:47 PM
  4. Noise help
    By GMPUNK in forum General Tech Discussion
    Last Post: 02-08-2009, 05:07 AM
  5. What do you think this noise is?
    Last Post: 07-03-2008, 09:54 PM
