Thread: GTP Noise....
Results 1 to 8 of 8
  1. #1 GTP Noise....
    SE Level Member SuperCharged0nE's Avatar
    Nov 2009
    KCMO
    I live on a gravel road with alot of pot holes and I got on the highway and got on it the other day and noticed a very loud whistling noise(no it was not the blower...) The whistling noise is louder than the S/C and is very high pitch...could this be an exaust leak of some sort? I'm really concerned about this...Opinions?
    Blown intake weld delete
  2. #2 Re: GTP Noise....
    SE Level Member gwog's Avatar
    Feb 2010
    Georgia
    Is it constant with throttle up? Change in pitch when moving?
  3. #3 Re: GTP Noise....
    Nov 2009
    KCMO
    Ya it doesnt start till I hit higher rpm's...the more RPM's the louder it gets...its louder than even the blower...sounds like...alot of air being pushed out of a pipe with a hole in it??? haha....Maybe i'm just loosing my head. I just cant seem to think of what it could be. its loud and high pitch...
  4. #4 Re: GTP Noise....
    Nov 2009
    KCMO
    Heres a vid of the noise.....bad road sorry...Just the audio of the noise to get a general Idea...
  5. #5 Re: GTP Noise....
    SE Level Member Ramondo411's Avatar
    Apr 2009
    Rotterdam,New York
    i would try the ac compressor, i had a similar problem an it seemed to be the compressor..it would scream soo loud i wouldnt be able to hear the supercharger. you should try taking your belts off, an spinning them individually with a steth o scope you should be able to figure which pulley is making that screaming noise. well hope it works out for ya.
  6. #6 Re: GTP Noise....
    Troy OH
    my truck sounded a lot like a teapot once. turned out it was a gasket under the throttle body, $4 part. could be a vacuum problem of some sort. i'd check hoses and gaskets
  7. #7 Re: GTP Noise....
    Nov 2009
    KCMO
    Come to find out I had a hole in the flex pipe before my cat and air was leaking out making a really loud whistling noise...
  8. #8 Re: GTP Noise....
  1. This noise
    By pontiackid in forum General Tech Discussion
    Last Post: 06-11-2009, 11:41 AM
  2. Odd noise, can someone help!!!
    By indybrad in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-23-2009, 02:06 PM
  3. Noise help
    By GMPUNK in forum General Tech Discussion
    Last Post: 02-08-2009, 05:07 AM
  4. .... Noise again
    By JCG's-GTP in forum Audio, Security & Visual Electronics
    Last Post: 07-24-2008, 04:15 AM
  5. What do you think this noise is?
    Last Post: 07-03-2008, 09:54 PM
