This writeup on Custom AN Fuel Line Modification has been added to the How To section and can be found HERE.
Nice, I am starting at the filter and going all the way to the rails, but I can't wait to see pics
Yeah, I just got the first few in the mail, and ordered the last set.....
Filter up on feed side and As far back as I have line for on the return(i bought 20 feet)
Now I just need a camera so I can do a write up
Finally! Got some pics of my AN-6 Fuel lines. Here they are....
Hope these explain it a little better!
So, why can't you use the spot where the flexible tubes meet the hard lines? Why cut all the way down there?
I guess I have a problem taking a dremel wheel to a gas filled line.
How do those fittings hold on to the smooth hard line?
no, my lines are the same size all the way through, i have them out.
i had a few other questions as well. what parts did you use for the lines that connect to the fuel rail itself, did you list those in your parts needed? also why do you need the 90 degree fitting? and why 3 XRP -6 AN straight female hose ends? why not 4?
your write up or how to seemed very vague to me, i guess i need more details
i bought all the stuff on your list minus 6 ft of hose because im not going back far, just removing the plastic fitted stuff, but i still wonder where are the fittings that i need for the rail. i found these - http://store.summitracing.com/partde...5&autoview=sku is this what i use?
Do you have to do anything else to the line besides cut it? No flaring? And... about the cutting... I take it that it is much more safe to drain the fuel from the lines first?
I have a question about the Earl's hard line fitting, they seemed to be good to only 50 PSI, don't we have more than that at WOT ?
Earl's Hard-Line AN Tube Fittings - JEGS
No Dremel, pipe cutter
No flaring the lines at all. I listed the PNs and pictures on the link above, heres the link, http://grandprixforums.net/fuel_line.php. Once you see them, you'll figure it out. Just make a nice, straight, clean cut and your good. As for draining the lines, I didn't. I just had a bucket handy for the excess fuel, thats it. Suck out the lines once you cut them, thats it really...
Just to show anyone can do it, here are the pics from mine((i just loaded em onto my PC today, but did the lines in early july)
An connection at the Filter
It goes with the other lines (return and evap)
Almost looks like it should be there
Last bracket before Firewall
Hardline connector for the return, my 2.5 dp and gmpp sway in the background..and feed running along return
Hardline adapter to 90* to stainless, was enough room for feed to make this turn without a fitting
Comes up next to the steering rack and goes to the Drivers side of the brake booster
If you can find it in this pic, you will see it curving around the brake booster
Can you even find em in this pic?
And they reapear from the top of the brake booster and under the Strut bar
And they arrive at the Rail:bigthumb:
As slowly as other things are moving on my car, maybe I can get this knocked out. What size line do I need? I know feed and return lines are different sizes, do I need to match that with the lines or can you use something like 3/8 - 5/16" SS lines and connectors?
Use AN-6 for both sides, thats what everyone does. I used AN-6 (3/8") on both sides. To make this work I used Earl's -6 AN Male to 3/8 in. Tube for one side, and the other I used Earl's -6 AN Male to 5/16 in. Tube for the other. Worked great!
DON'T USE A TUBE NUT + SLEEVE, IT WILL LEAK MOST LIKELY!!!
Read my instructions for more info...
