Thread: DIY rusted strut tower fix for dummies(Ive never done this before)
Results 41 to 46 of 46
Threaded View
  1. #1 DIY rusted strut tower fix for dummies(Ive never done this before)
    Sep 2013
    Exeter
    So I've been looking everywhere for help trying to fix my rear strut tower's and there's not much out there. So I'd like to add my experience to the internet and hopefully it will help somebody who's having similar problems. Im not done yet but and any help or idea's would be greatly appreciated here's a look at the progress so far and a look at what I'm using I am but no means a professional I'm a DIYer that wants to learn how to fix everything that breaks I spent some money on this project but mostly I'm using cheap tools and I make do with what I got. I don't even have air tools (yet) my budget most included buying the welder for this project.
    Tools used:
    lincoln 180 mig welder 220v (running flux core)
    electric angle grinder (cutting/cleaning)
    wire brushes
    18v electric drill
    about 3'sq of 1/8 steel
    80 grit sandpaper and block
    pry bar (pipe in my case)
    Socket set
    Adjustable wrench
    rust pentertor like luquid wrench (a must for any rusty vechile)
    Ok so get your strut tower out of there I left my wheel bearing brakes and everything alone just hanging there after they were unbolted from the strut tower assembly. After you remove the 2 bottom bolts. And the connector arm above it. You can unbolt the 3 in the trunk I left my one jack stand sitting under the strut tower to hold it up when the bolts let go. Do some manhandling and it should come out fairly easy just push down and then out watch you don't get stuck on your wheel hub. And were left with this
    [IMG][/IMG]
    So I got my angle grinder which kind sucked to work with in this situation if you have air tools that would make it alot easy to cut as the electric grinder is pretty bulky and made it hard to reach some spots. But anyways I cut out all the lose bad steel I could reach which I think I got most of it wish I could of got abit more on the right side of the picture but Couldnt get my blade in there without making a mess. But I tried to leave about an inch of metal along the edge opposite of the mount in order for it to be guide for were the new patch should be.
    [IMG][/IMG]
    Then I got my pry bar which is acctualy a pipe. I used it to bend the mount back down into its original position eyed it up though but from what I read it shouldn't make be a huge deal if it's off slightly. But I do think I got it pretty close to dead on that picture doesnt show the end result to well Ill put a better updated picture within next couple days with more progress.
    [IMG][/IMG]
    So yeh next update I'll have it all cleaned up and how I did with cheap electric tools you probably already have around the house and hopfully by the end of this we have a fixed car( for now) The main plan is to weld a patch of 1/8s steel around the edge of the mount onto the edge on the car runs along side the mount.I've done alot research from the bits I can find hopfully this keep's the car solid for a couple years.
    Also would anybody recommend getting a used strut tower from the scrap yard or is that part that's better to buy new as I think there like 80 bucks new?
  1. rusted strut towers. welder needed
    By GPJoe in forum Northeast
    Last Post: 07-13-2014, 10:58 AM
  2. rear strut mounts rusted all the way through?
    By nickgpgt in forum Brakes/Suspension/Chassis
    Last Post: 10-22-2013, 07:08 PM
  3. Rusted strut mount fixed on project car!!!! (Pics)
    By BlackGT97 in forum Members Rides
    Last Post: 10-13-2012, 02:01 PM
