Ok, minor issue. After replacing the thermostat I can't seem to get the air out of the system. Ends up boiling out of the cap neck before the bleed screw ever has a constant flow of coolant. Any bright ideas for how else I could get the air out of the system without having to fill directly from the thermostat area. I put the RTV sealant around that housing, so I'd like to avoid taking that off and redoing that process if at all possible. Thanks for any pointers.
