Thread: Motor Temp Creeping Up
Results 1 to 8 of 8
  1. #1 Motor Temp Creeping Up
    Apr 2008
    New Hampshire
    I am new to the site i just want to give a thumbs up to everyone posting you guys all know your stuff and are a HUGE help to people like me who just bought their GP last week. When i bought the car i knew that the intake manifold gaskets were a common problem with the 3800. This afternoon sitting in traffic in Boston the temp started creeping up but only got to about 210 before i got back on the highway and it was fine. A few other times when i got off the highway i caught it creeping up again but not quite so high. I am suspecting that i need to replace upper plenum and lower gaskets but just wondering for any adivse of possible performance upgrades while im in there or maybe if i am missing the diagnosis here. I plan to pressure test the system in the morning at work but any advise would be much appreciated! Thanks everyone!
  2. #2 Re: Motor Temp Creeping Up
    Barksdale AFB, LA
    I don't think you have a problem yet. If it gets much higher, then yes. When you stop its going to heat up fairly quickly in warm weather. Stock fan turn on is just past 200* so they won't be helping until that point.
    You need to do a controlled situation where you let it sit and watch the gauge and see when the fans come on. Both fans should be on by 210 and it shouldn't get any higher than that sitting still idling.
    2009 Subaru Impreza WRX STI
  3. #3 Re: Motor Temp Creeping Up
    Apr 2008
    New Hampshire
    That is a definate possibility. I will have to give that a try. Except that the temp would not go down until i was cruising on the highway for a few miles.... seemed a little weird to me. And temperature here didnt even get the 55 degrees today so i am just nervous with summer on its way. If it stayed at 210 today what would happen on a day in the 80's or 90's....
  4. #4 Re: Motor Temp Creeping Up
    Barksdale AFB, LA
    Your thermostat doesn't even open up until 195*, so until then your radiator isn't even being used. The car's normal operating temp is about 195-205* and you were just a little above that, sitting in traffic. To be expected.
    Like I said a controlled test, along with your pressure test will shed some light on the situation.
  5. #5 Re: Motor Temp Creeping Up
    Apr 2008
    New Hampshire
    So i tested the cooling system at work today and pressure testing didnt show anything. I also let the car run for about an hour after driving to work and the temp didnt move and the fan never came on.... so i really have no idea
  6. #6 Re: Motor Temp Creeping Up
    PA
    So the system isn't holding pressure? Is that what you mean?
    Something that many people overlook is the radiator cap. Just like any other part on a car, it wears out. And if the cap wears out, it won't hold as much pressure, and can let the car heat up more than normal. A new cap could be an good idea.
    2001 GSE
  7. #7 Re: Motor Temp Creeping Up
    Saraland Alabama
    I also had an issue where the guy who had done some service before i got the car didn't bleed the system correctly and it did that
  8. #8 Re: Motor Temp Creeping Up
    This problem can happen when you do not have enough coolant, granted the low coolant light should be on but sometimes they break and either stay on all the time or just never come on. The temperature sensor is in a very bad position so if theres not enough water in there it wont read a correct temperature or if theres a pocket of hot air in there it will take the temperature of the air. Also you definitely want to look into the lower intake manifold gaskets and also, have someone rev your car some and if you smell antifreeze in the tailpipes you know you have an issue, and hopefully for your sake that isn't what it is. That happened to me and all I have to say is I emptied my cylinders that were full of coolant into a bucket...not fun.
  1. ambient air temp sensor
    By Toasty in forum General Tech Discussion
    Last Post: 09-10-2011, 10:12 PM
  2. how long and what temp in the oven to separate corner lense?
    By Zainoman in forum Off Topic Discussion
    Last Post: 03-15-2008, 02:40 AM
  3. Motor Trend First Look '09 ZR-1...
    By newfie in forum Off Topic Discussion
    Last Post: 01-23-2008, 07:58 AM
  4. Pics of motor
    By RED GTX in forum Turbo
    Last Post: 01-22-2008, 08:26 PM
  5. What temp should a 2004 GTP run at when warmed up?
    By Edmonchuck in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-20-2008, 11:34 PM
