Thread: Engine Coolant Temp Fluctuating
Results 1 to 20 of 41
  1. #1 Re: Engine Coolant Temp Fluctuating
    GT Level Member UCF04GPGTPCompG's Avatar
    Nov 2009
    Clermont, Florida, USA
    The way I bled it out was by leaving the radiator cap open, bleeding it, and then filling it the rest of the way. Then filling the resevoir.
    2004 Pontiac Grand Prix GTP Competition Group (250K)
    Engine Mods: K&N Air Intake, ZZP 3'' Downpipe w/MagnaFlow Cat
  2. #2 Re: Engine Coolant Temp Fluctuating
    Nov 2009
    Ok, minor issue. After replacing the thermostat I can't seem to get the air out of the system. Ends up boiling out of the cap neck before the bleed screw ever has a constant flow of coolant. Any bright ideas for how else I could get the air out of the system without having to fill directly from the thermostat area. I put the RTV sealant around that housing, so I'd like to avoid taking that off and redoing that process if at all possible. Thanks for any pointers.
  3. #3 Re: Engine Coolant Temp Fluctuating
    you are using the bleeder screw on top of the t-stat housing right?
    i leave the rad cap off, let the car idle till the fans come on, that way you know the t-stat opened up, top off rad if needed, loosen the bleeder screw, keep open till a stream of coolant comes out, shut screw, top off rad, cap it.
  4. #4 Re: Engine Coolant Temp Fluctuating
    Nov 2009
    That's pretty much what I did the first time i did it. Maybe I'm opening up the screw too early. I'll try it out tomorrow with keeping the screw tightened till the fans kick on. See how that works.
  1. ambient air temp sensor
    By Toasty in forum General Tech Discussion
    Last Post: 09-10-2011, 10:12 PM
  2. temp on aeroforce and temp on dash
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2008, 01:05 PM
  3. Temp fluctuation
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 10-11-2008, 08:28 PM
  4. Engine Coolant Question
    By dowtrader in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-11-2008, 03:03 PM
  5. Motor Temp Creeping Up
    By Gearhed42 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-11-2008, 06:05 PM
