looks like this when done. now that i have the power supply im gonna buy a two side plug to plug the off board into the p/s. so its not rigged up twisting them together. my switch has no on / off labeled on it, so i marked it.
being that it looks like your tuning now. dhp can and will brick your pcm someday. its a risk. so what i would do if i was you is to go to a junk yard, find a year car your car can use the pcm from, buy the whole air box, cut the wires to the pcm plug, rip the obd2 port out the car, and drop it all in the air box. now go pay for that air box lol i bought 2 air boxes for 12 each. one had the pcm plugs and all in it, the other just the pcm.
this way you can flash a stock tune to it, and have a back up, or flash your last known good tune to it, as a back up. you can also change the vin# in the pcm you your # in vin maintenance.
