Quote Originally Posted by Turbocharged400sbc View Post
just get a 4 diode rectifier and your golden. made this for 04+ but ive added a 96-03
i love ****ing with people and connecting it to the battery backwards
yup sloppy ass ****. i clipped the terminal wires off flush with the connector, and jammed a pick in em to open em up (the bolt free 02 conn still has several that arent opened up to keep the connector held in place.
if you want a sloppy off board do it your way.
and this is gp board, not a park ave or whatever board, this is what works for most of us, regal, or gp. we dont need to tune those other cars or look up how to make a off board for them.
i dont see you points here at all. follow that diagram and it will work for us 97-03 guys.
im just pointing out that if your finding pcm connectors that arent lining up, just use the diagram for the donor, snip wires, be on your way. your reworking the **** out of a connector, labor that should go towards more important parts of the project.
Quote Originally Posted by BrandonHall10 View Post
As far as leaving wires in, or taking them out... To each their own. There is no wrong way. God bless America, we get to do what we want. The only reason to pull them out, is to not have to look at them. Aesthetics. That is exactly my reason. If someone wants to leave them in and just cut them short, I'm not mad.
Tell me more about this 4 diode rectifier thing.
its a diode cluster rectifier...not much else to say, its cheap, wire up the output to offboard, put inputs to alligator clips for the battery. dont even have to label em (id did mine since my led droplights use the same connector and they run off a car battery quite well (it also allows me to use the offboard with my lights 12v 110v power supply and connector...kill 3 birds, one connector
oh. if you ditch that grey plastic cover on the back side, you can bolt the obd2 port to the metal frame on the side with no wires through it. makes it look clean like that. and easy to use with no wires all over. you'd just have the neg and pos wires leading from both plugs and the switch.
some people dont even use a switch, just hard wire those wires with no switch. its your call there. i like the switch.
if ya keep the switches, make sure they are well protected, inside a recess. my switches can only be turned off by a finger sized object. if someone dropped a cylinder head on it it would only turn the switch on, and never off.
to each their own
btw if you want the lazy way AND the fat wires, look for the 98 and earlier pcm connectors...them 96's actually used proper sized wire before gm cut the costs by cutting the copper down, since cars required more and more wire each year.
i cant be the only guy that noticed the pcm pinout differences and actually investigated the pcm pin connections am i?
