Thread: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
Page 5 of 9 FirstFirst ... 34567 ... LastLast
Results 81 to 100 of 177
  1. #81 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    did the pan drain out the corner of it? if so theres some more in side, hold the pan up, remove the bolts, lower the pan as level as you can, then dump it into the drain pan.
  2. #82 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    GT Level Member 2FASTGTP's Avatar
    Apr 2012
    Indiana
    Wowzers..pan off. Bolts that broke are not gonna be easy to get out at all.
  3. #83 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    Dec 2012
    Where 4T65E's were born
    Got any reverse drill bits?
    Sold.
  4. #84 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    is drill and extractor time for sure. or them reverse bits do work too.
  5. #85 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    Apr 2012
    Indiana
    No reverse drill bits. This sucks haha I bought an extractor but it didnt come with a drill bit so I gotta go get a new one tommorow. What size should I look for?
  6. #86 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    How did you manage that one, before I remove or tighten any bolt I always double check that my ratchet is going the correct way. Righty tighty lefty loosy.
  7. #87 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    Quote Originally Posted by 2FASTGTP View Post
    on the package the extractor comes in it will say what size bit to use.
  8. #88 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    Apr 2012
    Indiana
    So just to be clear before I reinstall accumulator, piston with the thinner top spring has only the 2 springs below (which rattles when you shake accumulator ) goes closer to where the 3 lines enter?
  9. #89 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    GTP Level Member
    Aug 2012
    st louis park, MN
    You should be able to tell if you look closely at the picture in the instructions. I got confused too when I did it.
  10. #90 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    Apr 2012
    Indiana
    Yeah I just cant tell which top spring is larger in the instructions. I think 1-2 is closer to the 3 lines, with the smaller spring on top and only the 2 springs on bottom.
  11. #91 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    Dec 2012
    The 1-2 accumulator gets 2 springs. Its stamped 1-2 right on the accumulator so you shouldn't mess it up. And yes the 1-2 is also next to where the lines go.
    Sold.
  12. #92 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    Apr 2012
    Indiana
    Ok can you assure me that the 1-2 is the one with the thinner spring on top?
  13. #93 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    Dec 2012
    Why? Did you mix the pistons up? I don't remember the springs being different. You'll have to search around or look at my pictures, I'm not sure it would matter.
    Sold.
  14. #94 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    Apr 2012
    Indiana
    Well I didnt realize that they were different till now, so just wanna make sure I have it right.
  15. #95 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    Dec 2012
    Do you see paint on the springs? I'm my pictures you can see one is red* and the other is white
    Sold.
  16. #96 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    Apr 2012
    Indiana
    I verified with your picture...you can tell the 2-3 has much larger coils.
  17. #97 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    Dec 2012
    Alright well there you go.
    Sold.
  18. #98 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    Apr 2012
    Indiana
    Thanks for the write up BTW
  19. #99 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    Dec 2012
    No problem..glad to help
    Sold.
  20. #100 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    Feb 2013
    Missouri
    Great write-up! Just to add a bit, I went from the DIY shift kit to the Transgo kit, and ended up doing a mixture of both. I ended up leaving the 2-3 spring in the 1-2 accumulator, left the "top" 1\2" spacer on the top of the 1-2 accumulator, and put 3 springs in both of the accumulators. At the end of the day, both the 1-2 and 2-3 accumulators were the same...with the exception that the top spacer on the 2-3 accumulator is .053" and the spacer on the 1-2 accumulator was .050".
    I did this around a month ago and reset my TAP's when I installed it, and so far I love it. It's had plenty of time to learn the new shifting behavior, and it shows. Very crisp shifts, that don't break your neck. I've always wanted my transmission to shift from 1-2 like it does from 2-3, and I think this is as close as I can get, really. I'd recommend doing this mixture, if you want the 1-2 a little quicker and maybe a little more firm. Like I said, it's nothing crazy and still VERY drivable. My mother in law just bought a 1999 GP GT with 171k on it, and it shifts like CRAP compared to mine. It doesn't shift bad like there is a problem with it, I just forgot how sloppy the 4t65e is in stock form, lol.
  1. Transgo Shift Kit-
    By GTByron in forum Introductions/Noob Questions
    Last Post: 04-01-2013, 01:18 PM
  2. Transgo Shift Kit Install Help
    By matthew911 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-15-2012, 06:22 PM
  3. transgo shift kit install Q
    By GTPJOE90 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-10-2012, 11:19 AM
  4. 4t60e or 4t65e
    By gpboi19 in forum Introductions/Noob Questions
    Last Post: 02-02-2010, 05:21 PM
  5. Thrasher vs Transgo shift kit
    By anks106 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-03-2008, 10:21 PM
