When I take out these last two bolts, is fluid gonna spill everywhere?
If the pan is full yeah, hold it up remove the last bolts and carefully drain it into your drain pan. Or pull a me and drop it on your face.
Sent from the Milky Way
did the pan drain out the corner of it? if so theres some more in side, hold the pan up, remove the bolts, lower the pan as level as you can, then dump it into the drain pan.
Got any reverse drill bits?
How did you manage that one, before I remove or tighten any bolt I always double check that my ratchet is going the correct way. Righty tighty lefty loosy.
So just to be clear before I reinstall accumulator, piston with the thinner top spring has only the 2 springs below (which rattles when you shake accumulator ) goes closer to where the 3 lines enter?
You should be able to tell if you look closely at the picture in the instructions. I got confused too when I did it.
Yeah I just cant tell which top spring is larger in the instructions. I think 1-2 is closer to the 3 lines, with the smaller spring on top and only the 2 springs on bottom.
The 1-2 accumulator gets 2 springs. Its stamped 1-2 right on the accumulator so you shouldn't mess it up. And yes the 1-2 is also next to where the lines go.
Why? Did you mix the pistons up? I don't remember the springs being different. You'll have to search around or look at my pictures, I'm not sure it would matter.
Do you see paint on the springs? I'm my pictures you can see one is red* and the other is white
Alright well there you go.
