Thread: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
Page 3 of 9 FirstFirst 12345 ... LastLast
Results 41 to 60 of 177
  1. #1 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    Dec 2012
    Where 4T65E's were born
    Well it's no longer free so... It's almost done being updated, I've got a few more to go which I'll finish tomorrow.
    Sold.
  2. #2 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    Florida
    could always upload them in the thread...
    got my transgo shift kit installed yesterday. went pretty well except for my trans dipstick tube seal must have a crack as i leaked 1/4 qt of fluid. I was freaking out thinking the pan wasn't sealed and almost broke one of the bolts checking to make sure it was tight. so far it shifts great again and no code yet (1811).
  3. #3 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    Dec 2012
    Quote Originally Posted by Z34Phoenix View Post
    The how to looks nicer with the images linked in where I want them. That seal should be pretty easy to replace. Glad to hear it shifts better, my max adapt hasn't come back since. Shifts don't get sloppy anymore.
    It's all updated now. I also added more info, suggestions, tips, etc. Now onto my other how-to's to update those photos.
    Sold.
  4. #4 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    Oct 2011
    Toledo, OH
    Good job! I ordered my transgo kit, the lube tube clamp and a new filter. Likely going to put DEX3 back in, as I had put DEX6 in a few months ago, and it feels different.
    7"
  5. #5 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    How different? Like slipping?
    Sent from the Milky Way
    2012 F150 STX
    - Gonna be a race truck
  6. #6 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    Dec 2012
    Well any time you change the fluid it will feel different for the first week or less, whether you unplug the battery to reset it or not. Yours came with III from the factory, if it's been rebuilt VI will be fine. If not it's your choice. But the shift kit makes shifts quicker, meaning better so I assume you meant it was different in a not so good way.
    Sold.
  7. #7 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    Oct 2011
    Toledo, OH
    Not slipping, just slow or hang shifting when driving at a leisurely pace. Shifts normal at WOT though. It's been 3-4 months too, pulled the battery at least 3 times since then. Hasn't been rebuilt, just only changed the fluid and filter.
    7"
  8. #8 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    Dec 2012
    Are all the shifts the same or is it specifically the 1-2 or 2-3?
    Sold.
  9. #9 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    Oct 2011
    Toledo, OH
    Pretty sure it's the 2-1 downshift delay I notice most. Best example is when I leave work I have to slow down for a yield sign, and when I get back on the throttle it hangs in gear (2nd I assume) for a few seconds at a low RPM before down shifting to let me accelerate.
    7"
  10. #10 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    Quote Originally Posted by industrialfish View Post
    Mine does that too.
    Sent from A Galaxy Far Far Away........
  11. #11 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    Dec 2012
    Well I know the stock 4t65e downshifts horribly(at half throttle area), I noticed on mine for sure. You hit the gas, hear the engine rev, then a second later finally feel the power of the lower gear. The shift kit made those 100% better. Now I've had the shift kit for a while, our impala doesn't have one and its up shifts are always quick and firm without a kit. But the downshifts...man they're slow. I'm going to do a shift kit and filter/fluid on that this summer.
    Sold.
  12. #12 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    Arizona
    Tuning can take care of that
  13. #13 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    Dec 2012
    Well if it hangs in the gear for a second the PCM is deciding whether or not to go back down to first I guess. What I meant was it already commanded it because you can hear the engine rpm's rise, but can't feel the power until a second later. It hasn't done that since the shift kit was installed, when you hear it shift you feel the power instantly. But what you might be saying is that it doesn't command 1st gear as soon as you hit the gas, yeah mine does that as well. Tuning would change that kind of stuff.
    Sold.
  14. #14 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    GT Level Member 2FASTGTP's Avatar
    Apr 2012
    Indiana
    Im installing my shift kit today and I just when and checked my tranny fluid level only to find it reading well above the normal operating level line.....this is the first time Ill be adding fluid so what the heck?
  15. #15 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
    Quote Originally Posted by 2FASTGTP View Post
    It should be noted that the transmission fluid level should be checked when vehicle is at normal operating tempature and on flat level ground. This doesn't mean run it down the road at 100mph and come back and check it. But, start it, cycle manually through all PRND321 Positions, and let it come up to operating temp. Then check it.
  16. #16 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    Apr 2012
    Indiana
    Yeah I just realized that. Haha thanks. So once I get everything reassembled, I add about 7 quarts of Dex III , start it and run it through the positions, check level, and add more if necessary?
  17. #17 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    May 2011
    Illinois
    That's a fantastic place to start.
  18. #18 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    Apr 2012
    Dayton, OH
    I usually add about 6 quarts, start it, check level and add untill level is reached.
    2012 F150 STX
  19. #19 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    Apr 2012
    Indiana
    This Castrol Transmax Dex/Merc is what I need right?
  20. #20 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    Apr 2012
    Dayton, OH
    Me personally I don't like the multi use crap but it works snd I think I used that in my car last time I did a pan drop, I got valvoline DEX VI from napa for like 6.99 a quart or so and used that when I did my moms LaCrosse. Its just a better fluid over Dex III
    2012 F150 STX
  1. Transgo Shift Kit-
    By GTByron in forum Introductions/Noob Questions
    Last Post: 04-01-2013, 01:18 PM
  2. Transgo Shift Kit Install Help
    By matthew911 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-15-2012, 06:22 PM
  3. transgo shift kit install Q
    By GTPJOE90 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-10-2012, 11:19 AM
  4. 4t60e or 4t65e
    By gpboi19 in forum Introductions/Noob Questions
    Last Post: 02-02-2010, 05:21 PM
  5. Thrasher vs Transgo shift kit
    By anks106 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-03-2008, 10:21 PM
