Thread: Mod to the console shift indicator
Results 1 to 20 of 37
  1. #1 Mod to the console shift indicator
    SE Level Member Elrodd384's Avatar
    Mar 2012
    Fort Campbell, KY
    So my little orange deal wasn't moving correctly, so instead of fixing it, I decided to removed the indicator completely and had a sticker made to light up at night. Enjoy =)
    This is the channel that the plastic piece with the PNRD321 sits in. Years of soda and red bull built up yuck. cleaned it up with some acetone.
    Spent quite a while wet sanding the back where the PNRD321 is painted on. I used acetone, 3000 grit paper, and a lot of elbow grease. I also wet sanded the top side to ensure a flat surface for the vinyl.
    All cleaned up! I tried to 'blur' it up as much as I could to ensure the light would diffuse over the whole surface.
    Sticker added to the top side of the plastic piece. I had the sticker made flat black from House of Grafx House of Grafx, Your One Stop Vinyl Graphics Shop. It's 5 1/2 inches X 1 inch.
    Just a picture of the shifter without the piece.
    Slide the plastic back in very carefully to avoid damaging the sticker.
    Back in the console.
    You can kinda see the flange that would be the edge of the indicator in the middle there, that needs cut out because it goesright down the middle of the 'supercharged' and cuts off the light
    Did the best I could with what I had as far as tools(dremel would've been ideal) and notched in for the LED strips. Ended up putting one on top instead of down in the channel.
    just another view of the notches.
    The wires for the LED strips then get spliced into these wires for the stock 194 bulb. Black is ground, gray is power from the parking light circuit.
    Gonna try and figure out a better way to light it/disperse the light
    And TADA! pretty cool little mod that was cheap and fairly easy.
  2. #2 Re: Mod to the console shift indicator
    Donating Users JLiss's Avatar
    Dec 2012
    Aurora, IL
    nice work. cant wait to see final lighting pics.
  3. #3 Re: Mod to the console shift indicator
    SE Level Member Chaparral's Avatar
    Dec 2012
    MI
    Yes i would like to see the lighted product very much.
  4. #4 Re: Mod to the console shift indicator
    looks cool, you need a diffuser of some sort for the light under the supercharged logo to break up the light. like a ceiling mounted fluorescent light cover.
  5. #5 Re: Mod to the console shift indicator
    Mar 2012
    Fort Campbell, KY
    Yeah I was thinking about taking the plastic back out and roughing up the back to make it more foggy, but i'd rather not go that route
  6. #6 Re: Mod to the console shift indicator
    this is what im talking about, they sell it at home depot or lowes.
    2' X 4' Clear Acrylic Prismatic
    you can cut this to fit under the logo, if you could set it so its 1 inch under the logo, then put the lights under the diffuser. should break up the light and spread it around.
    maybe even point the lights down. so theres not such bright spots.
  7. #7 Re: Mod to the console shift indicator
    Mar 2012
    Fort Campbell, KY
    hmmm yeah I could cute that to fit down in there fairly easy. only thing about pointing that other one to the side like the one on the left is that it doesn't really reach the edge of the worde. i wish the strips would've been an inch longer
  8. #8 Re: Mod to the console shift indicator
    Donating Users Nickell's Avatar
    Dec 2008
    Cedar Rapids, IA
    you could almost get a matte clear graphic from house of grafx to cover over the top of the led strip to diffuse/dim down the lights
    1998 GP Daytona - PLOG, 104's, PRJ Wires, Lucas 42.5's, DHP 1.0 Tune, DP, Full Borla, GPO's, Roof Rails, Gen 2 Spoiler, 04+ Needles, Menards Intake, 3.5 Pulley, SSC Springs, Corn-fed
    2000 Bonneville SSEI - 212k+, New Gaskets and Stuffs
  9. #9 Re: Mod to the console shift indicator
    Mar 2012
    Fort Campbell, KY
    I was thinking about that nick, or painting the back of it with a matte finish clear coat
  10. #10 Re: Mod to the console shift indicator
    Texas
    Awesome
    85 Corvette
    01 TA
    03 Z06
  11. #11 Re: Mod to the console shift indicator
    I live here. TLSheff's Avatar
    Not a bad idea. Why didn't I ever think of this???
  12. #12 Re: Mod to the console shift indicator
    GTX Level Member Neil98gt's Avatar
    May 2011
    Kansas city
    I like it, it just seems way too bright. Definitely need to get the "su" and "ed" lit up.
    98 GT 2dr 116k, Sold
    07 Lexus ES350 Obsidian Black. Premium Plus package, sold
    2013 Hyundai Elantra GT
    2002 Grand Prix GT 4dr
    Quincy, Mass
    Get one of the smaller led strips like they have at autozone, should distribute the light better.
    No more GP 04 Impala SS Indy:
    Aug 2011
    Kenosha
    I have also heard of people sanding the tips of the led's to eliminate hot spots.
  15. #15 Re: Mod to the console shift indicator
    GT Level Member 00GT's Avatar
    Dec 2011
    Michigan
    Looks good
    SE Level Member Wsmccoy's Avatar
    May 2012
    Fort Campbell, ky
    I noticed it today when I looked in your car. I like it
    Quincy, Mass
    My other thought, I was going to replace that bulb with an led strip too, was to line the inside of the area with shiny metal tape to make the entire area reflect the light.
  18. #18 Re: Mod to the console shift indicator
    Mar 2012
    Fort Campbell, KY
    So I bought a dremel and cleaned it up. Moved the lights as well.
    Picked up a diffuser at home depot and cut a small piece to fit over the LEDs. I'd suggest warming the diffuser before you cut it.
    Finished product thanks to the guys for the input and ideas to make it better!
  19. #19 Re: Mod to the console shift indicator
    that looks solid now, the lights spread out real even now.
    good JOB!
    Aug 2011
    Kenosha
    Definatly looks a lot better. Awesome job.
  1. Replies: 1
    Last Post: 12-08-2012, 07:39 PM
  2. perf shift indicator in 98 dic wireup
    By goldgp in forum Audio, Security & Visual Electronics
    Last Post: 10-30-2012, 06:30 PM
  3. no shift indicator light
    By Linebacker in forum General Tech Discussion
    Last Post: 07-04-2012, 04:44 PM
  4. shift indicator light in cluster not working after gtp trans swap
    By Wisconsingrandprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-25-2012, 02:43 PM
  5. how to change shift indicator light?
    By nwulf1 in forum General Tech Discussion
    Last Post: 02-17-2011, 03:04 AM
