Thread: Adding Performance Shift [*]
Results 1 to 20 of 71
Threaded View
  1. #10 Re: Adding Performance Shift [*]
    St. Louis Mo.
    Quote Originally Posted by WhiteGT View Post
    I mean if the stock pcm will work with the perf shift or will I have to get the pcm out of whatever car I get the shifter and wiring from? Thanks.
    First off you do NOT need the performance switch leather knob to enable your performance shift. If you read my write, I said in there you do not need the shift knob to activate it. You need simply a flip switch to activate and deactivate the PS mode. You just need to have the wiring setup for the PCM to switch it on and off. And you can have a grounded flip switch on the dash or center console if you want to do the same thing as the leather shift knob would do.
    Its really just a preference to keep my car looking as close to stock as possible inside.
    James Shafer
    St. Louis MO
  1. Shift Kit[*]
    By Trannyman95 in forum How To Write-Ups/Tech Tips
    Last Post: 06-03-2012, 01:40 PM
  2. Bad Wreck Photos
    By GTPluv in forum Off Topic Discussion
    Last Post: 12-17-2007, 12:12 PM
