Quote Originally Posted by GeddyLee View Post
It will not light up until you have your performance switch installed and the PCM is setup to have it run. It was in my 98 GT's DIC and it never light up when I started my engine. It only will light once its engaged.
GeddyLee: By engaged I'm assuming you mean that the setting is turned on in the PCM. Is that right? Who would I go to to have that checked/changed? would a dealer do it? or must i find someone else? I'm out here in easter Idaho and have no Idea where to look for that kind of thing.
For the record, I already have a PS switch factory installed in my GTP. The little Blue Dash Indicator does light up when the switch is pressed in, but i'm trying to get the DIC to light up also.
