Quote Originally Posted by littleboybluebvc View Post
I've read a few of your posts and was wondering if you did anything to get your DIC to light the perf. shift indicator.
i've got a '98 GTP and can see a vague outline for it on the DIC, but it doesn't ever light, even when turning the key and cycling power. do i need to run a wire to the PCM like in the mod, or is it something else?
Any help would be appreciated...Thanks.
It will not light up until you have your performance switch installed and the PCM is setup to have it run. It was in my 98 GT's DIC and it never light up when I started my engine. It only will light once its engaged.
