More than likely it will work. All the GPs pretty much used the same PCMs, so in theory you should be able to activate the PS mode in your SE. I will not promise it will, as that I have never had an SE to know otherwise YES or NO it will work. You will have to have someone that has a DHP or a HPTuner to look at your tranny tables for the sections I have listed in the write to find out for sure if it is possible or not.
Good luck with it![]()
