Thread: How to replace a crank sensor
Results 1 to 20 of 52
  1. #1 Re: How to replace a crank sensor
    Tired of seeing stuff that has nothing to do with the procedure or topic in the How to threads. If you had something posted, please post it in the correct section. I deleted it.
  2. #2 Re: How to replace a crank sensor
    Oct 2012
    utah
    thanks Bill this information was awesome made it very easy for me take care of this issue with all your images in comments I appreciate it thank you. my pulley puller did not come with the right size bolts and with your post of what size bolt to use I was able to run up to the hardware store and grab exactly what I needed. I am pretty mechanically inclined but sometimes it's nice to just know what to do you have been very helpful and I believe the problem is fixed. thanks again bill
  1. 3 wire crank sensor vs 2 wire with 24x crank trigger
    By greenmachinegtp in forum PCM Tuning
    Last Post: 03-12-2012, 05:45 PM
  2. How to replace CPS (Crank Position Sensor) on a GTP?
    By jwjones in forum General Tech Discussion
    Last Post: 01-02-2012, 09:30 PM
  3. crank position sensor?
    By Mitchstrp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-29-2011, 12:45 PM
  4. camshaft sensor or crank sensor?
    By Viper in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-06-2010, 04:43 PM
  5. 3.1 crank sensor wire
    By 68galaxie500 in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-22-2010, 09:18 PM
