Thread: How to replace a crank sensor
Results 1 to 20 of 52
  1. #1 Re: How to replace a crank sensor
    GTP Level Member chris99gtp's Avatar
    Jun 2012
    Illinois
    is there any way of testing the sensor? i don't want to go through that and not know that its for sure whats wrong
    99 gtp- Burnt and gone
    01 gtp- Here to stay-3.4, SD Headers, AL104's HAI, Overkill PCM, SD Hood
  2. #2 Re: How to replace a crank sensor
    SE Level Member Wraith888's Avatar
    Twin Cities
    Quote Originally Posted by chris99gtp View Post
    For what it's worth - I found it to be a very easy process once I got a good air compressor and a good impact wrench. I didn't do a case learn and I've been driving it since for months now without any issues. The tach has been working perfect, the traction control light has stayed off indicating traction control is working and the engine hasn't missed at all.
    The check engine light did come on, but the codes indicated an O2 sensor going bad, so I replaced that and the sensor has stayed off since, so it wasn't any problem with the CPS.
  1. 3 wire crank sensor vs 2 wire with 24x crank trigger
    By greenmachinegtp in forum PCM Tuning
    Last Post: 03-12-2012, 05:45 PM
  2. How to replace CPS (Crank Position Sensor) on a GTP?
    By jwjones in forum General Tech Discussion
    Last Post: 01-02-2012, 09:30 PM
  3. crank position sensor?
    By Mitchstrp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-29-2011, 12:45 PM
  4. camshaft sensor or crank sensor?
    By Viper in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-06-2010, 04:43 PM
  5. 3.1 crank sensor wire
    By 68galaxie500 in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-22-2010, 09:18 PM
