Thread: How to replace a crank sensor
Results 1 to 20 of 52
  1. #1 Re: How to replace a crank sensor
    SE Level Member Wraith888's Avatar
    Twin Cities
    I don't know how the vice-grips thing is going to work for that bolt - I tried shoving a screwdriver into one of the three holes in the HB as well as a vicegrips and then a breaker bar to break things free and it wasn't going to happen. I saw a youtube video of someone who had made a special tool for holding the HB in place while he pried, but I would rather not make a custom tool for a job I may only do once or twice. Not sure how the no-tools method worked out for others - maybe if I had a 2nd guy on the vicegrips I could make it work...
    So I decided to buy an air compressor and an IR last night - got home too late to try them out, but that's the new plan.
  2. #2 Re: How to replace a crank sensor
    Quote Originally Posted by Wraith888 View Post
    Very simply, when you put the vice grips on the FLEX PLATE as suggested, it holds the motor from moving. You said harmonic balancer a couple of times and ...well there's nothing to grab onto on the balancer.
    The first thing you see is removing a splash shield to see the balancer. Then a line or two down is remove a plastic inspection cover to see the flex. Flex is connected to the torque converter of the transmission.
  1. 3 wire crank sensor vs 2 wire with 24x crank trigger
    By greenmachinegtp in forum PCM Tuning
    Last Post: 03-12-2012, 05:45 PM
  2. How to replace CPS (Crank Position Sensor) on a GTP?
    By jwjones in forum General Tech Discussion
    Last Post: 01-02-2012, 09:30 PM
  3. crank position sensor?
    By Mitchstrp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-29-2011, 12:45 PM
  4. camshaft sensor or crank sensor?
    By Viper in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-06-2010, 04:43 PM
  5. 3.1 crank sensor wire
    By 68galaxie500 in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-22-2010, 09:18 PM
