Thread: How to transmission 4th gear side cover access
Page 4 of 4 FirstFirst ... 234
Results 61 to 77 of 77
  1. #61 Re: How to transmission 4th gear side cover access
    Being a GP, you likely don't need them in the position to hold the gear selector bracket. I think that was primarily the H/C/G bodies in the 00+ years. You can put them in any position you would like. I put them up on top where it's easy to deal with them.
    I also replace those four on the bottom with regular case bolts (I have billions of spares) and never worry about that torx junk. There is no need for torx to be on the bottom that i can find.
  2. #62 Re: How to transmission 4th gear side cover access
    GT Level Member SilverBulletWI's Avatar
    Apr 2014
    Milwaukee, WI
    Thank you. I found some pics that show two of them on top but wasnt sure about the 3rd. Guess I'll just toss it in the line somewhere.
  3. #63 Re: How to transmission 4th gear side cover access
    See where the cable bracket is sitting on the trans in his link? That's where they were intended ...kinda
    http://www.grandprixforums.net/threads/91317-Trans-Info
  4. #64 Re: How to transmission 4th gear side cover access
    Apr 2014
    Milwaukee, WI
    I absolutely see what you mean. Thanks for the link.
  5. #65 Re: How to transmission 4th gear side cover access
    Apr 2014
    Milwaukee, WI
    Torque specs on side cover? Cant find them here or in 3800 torque specs thread
    Digitized from my thumbs to your screen by my Tab3
  6. #66 Re: How to transmission 4th gear side cover access
    Feb 2013
    Missouri
    18 ft pounds.
  7. #67 Re: How to transmission 4th gear side cover access
    SE Level Member AntonyJ1214's Avatar
    Newport News, VA
    I don't have a torque wrench can I just make sure they are good and tight and be good?
  8. #68 Re: How to transmission 4th gear side cover access
    Quote Originally Posted by AntonyJ1214 View Post
    Autozone rents them if you have a ride over there
    04 Comp G.
  9. #69 Re: How to transmission 4th gear side cover access
    Feb 2013
    Missouri
    This isn't really a job I'd do without a torque wrench. Especially the valve body\channel plate bolts, they get 106 inch pounds (most of them) and that's not very tight at all. At the same time, you don't want to go to loose.
  10. #70 Re: How to transmission 4th gear side cover access
    Nov 2012
    Based on the second picture which solenoid is the shift b?
  11. #71 Re: How to transmission 4th gear side cover access
    Kemmerer, Wyoming
    my father in law has a 2003 N/A impala that wont go into over drive. the car has 200,000 miles on it. if we change the 4th gear shaft, will the splines on the new shaft cause faster wear on the clutches and drive chain, or whatever the 4th gear shaft connects to? I have a new double chain that was intended for a gxp transmission to put in if the need is there.
  12. #72 Re: How to transmission 4th gear side cover access
    Pennsylvania, USA
    They will wear at the same rate as a correctly functioning 4t65e, no harm from a 4th gear shaft in good condition. If you want to be safe the Borg Warner 4th gear friction and steels aren't too expensive and don't have the overheating issue the stock ones tend to run into, you'll probably notice some scorch-type marks on yours. At 200,000 miles they may need replacing anyways.
    Someone correct me if I'm wrong, but I thought 2003 and up 4t65e's received hardened shafts from the factory? You may want to send an email to TEP performance for a professional opinion, no sense wasting money if the Impala already has the hardened shaft.
    For thine is the Cam, The Piston, and The Rod, Forever and ever (or until they break). Amen.
  13. #73 How to transmission 4th gear side cover access
    Mercer, Pa
    My 2003 SSEi had soft 4th shaft. Depends on manufacture date, not sure anyone knows what the exact date is.
  14. #74 Re: How to transmission 4th gear side cover access
    Kemmerer, Wyoming
    I heard that to, but it's an n/a impala so I'm not sure if it has the hardened shaft. If it's a cheap easy fix he may consider it but otherwise, the car has 200,000 miles so he isn't sure if he wants to do it or not
  15. #75 Re: How to transmission 4th gear side cover access
    Donating Users GoldGTP's Avatar
    Sacramento, CA
    Sorry to bump a 2 year old thread, but this thread seems the best to ask this question since I am doing this repair this weekend...
    While I was pulling the channel plate off, somehow all the "innards" (second drum, sprocket support, ect) apparently wiggled forward enough for the sun gear input shaft to be pulled free...
    I know this sounds weird since the chain on the outside kinda holds it all in place (chains might be toast), although this isn't a bad thing since I found another culprit to my no 4th while I had all the guts laying in my hands after fully taking off the chain...The sun gear input shaft is stripped out where the 4th shaft inserts into...(so i have a stripped combo of the 4th shaft and sun gear input shaft)
    So it is kinda good everything fell out into my hands!
    Also, after reviewing some videos on youtube, I noticed my 2nd clutch has "excessive" clearance between the clutches...
    The reason for posting here is to ask this question...
    When I get my replacement sun gear input shaft, what is the best method to getting "the guts" back in and the shaft into the sun gear?
    I have tried all kinds of things, although, it appears that when I have everything out (sprags, 2nd clutch, sprocket support) that it would be easier to have everything assembled outside the transmission and slip the whole shebang in, although this method is tough since the assembly is bulky and heavy...
    Any input as to getting everything back in after replacing the sun gear input shaft will be helpful!
    Hey tyler, where is the email man!?
    edit -- this video proves useful...
    https://www.youtube.com/watch?v=Nl5i...3-GZmH-Akbw52P
  16. #76 Re: How to transmission 4th gear side cover access
    Use this link to download the info you need.
    https://www.dropbox.com/sh/a98nnzizk...WBSdkG6Ta?dl=0
    As for assembling it, I assume the trans is still in the car. It's going to suck. You need to wiggle/jiggle and basically have the patients of about 10 saints in order to get lucky enough for it to slide back together. It's supposed to be assembled with the tailshaft facing down and therefore trying to put this wobbly mess together with it in a different position will be tricky. I have done it, but ... it too a lot of luck.
  17. #77 Re: How to transmission 4th gear side cover access
    Sacramento, CA
    Thanks for the links BillBoost, much appreciated!
    Quick question, do they make a hardened sun gear input shaft?
    Not the 4th, but the sun/planetary input shaft the 4th goes into...
    This bad boy (splines gone!)
    This is what I expected to hear...Also, not sure how i'm gonna tweak the chain when that comes time to install..
    Thanks for the input
  1. Transmission side cover help!
    By wrpfctr7 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-23-2011, 07:09 AM
  2. Popping noise from passenger side when in gear.
    By aeidian in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-01-2010, 10:46 PM
  3. Transmission shifting from 3rd to 4th gear
    By tbrereto in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-22-2010, 01:02 PM
  4. What is the Part# for MAP sensor access cover?
    By nault31 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-16-2010, 09:20 PM
  5. Transmission Code and no 4th gear HELP
    By JunkboxGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-23-2009, 02:03 AM
