Thread: How to transmission 4th gear side cover access
Results 1 to 20 of 77
  1. #1 Re: How to transmission 4th gear side cover access
    Being a GP, you likely don't need them in the position to hold the gear selector bracket. I think that was primarily the H/C/G bodies in the 00+ years. You can put them in any position you would like. I put them up on top where it's easy to deal with them.
    I also replace those four on the bottom with regular case bolts (I have billions of spares) and never worry about that torx junk. There is no need for torx to be on the bottom that i can find.
  2. #2 Re: How to transmission 4th gear side cover access
    GT Level Member SilverBulletWI's Avatar
    Apr 2014
    Milwaukee, WI
    Thank you. I found some pics that show two of them on top but wasnt sure about the 3rd. Guess I'll just toss it in the line somewhere.
  1. Transmission side cover help!
    By wrpfctr7 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-23-2011, 07:09 AM
  2. Popping noise from passenger side when in gear.
    By aeidian in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-01-2010, 10:46 PM
  3. Transmission shifting from 3rd to 4th gear
    By tbrereto in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-22-2010, 01:02 PM
  4. What is the Part# for MAP sensor access cover?
    By nault31 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-16-2010, 09:20 PM
  5. Transmission Code and no 4th gear HELP
    By JunkboxGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-23-2009, 02:03 AM
