Thread: How to pull an engine: BillBoost Style
Page 4 of 6 FirstFirst ... 23456 LastLast
Results 61 to 80 of 105
  1. #61 Re: How to pull an engine: BillBoost Style
    do not, i repeat, do not, use a used torque converter from a junk yard.
    if you get one thats from a blown tranny, you now also will have a blown tranny.
  2. #62 Re: How to pull an engine: BillBoost Style
    Dec 2011
    In the Garage
    I personally pulled an engine from a car in the junk yard that had a good engine and transmission. Since all is good, then I trust that the torque converter should be no problem being from a junk yard and also good. It's extra work to pull it yourself at this particular junk yard, but you pay $200 per motor, and you know it's good and where it came from.
    This particular car had 99K on the odometer and on carfax.
  3. #63 Re: How to pull an engine: BillBoost Style
    as long as your sure its off full working tranny, it should be ok.
  4. #64 Re: How to pull an engine: BillBoost Style
    Dec 2011
    In the Garage
    I got my engine pulled, and I salvaged my torque converter. All good here.
  5. #65 Re: How to pull an engine: BillBoost Style
    Mar 2015
    USA
    I hate to reply to a 2 year old thread, but this can go in the archives for future searchers.
    Can the oil filter adapter stay on and still clear the fender well? Alldata seems to think it needs to come off, but they also say to remove the W.P. pulley, and it clearly isn't in the way in your pics.
    I also can't get in good to tell, but can the extension harness that goes to teh crank sensor, rear knock sensor, etc stay with the motor as you pull it or does it go elsewhere?
  6. #66 Re: How to pull an engine: BillBoost Style
    Donating Users seventone's Avatar
    Mar 2013
    midwest
    The oil filter was still on. I am pretty sure I unplugged every thing.
    1997 Black GTP Coupe | 1997 Black GTP Coupe | 2001 Silver GTP Coupe | 2001 Red GTP Coupe
  7. #67 Re: How to pull an engine: BillBoost Style
    You can do it with it on. I've done it a bunch of times. It'll make it very close to the body and may scrape it's way up.
  8. #68 Re: How to pull an engine: BillBoost Style
    Mar 2012
    NC
    I've done it both ways...leaving the filter on just makes clearance a little tight. Taking the filter off doesn't necessarily make anything easier.
  9. #69 Re: How to pull an engine: BillBoost Style
    Mar 2015
    USA
    Sweet. Now that I look closer, I can clearly see the filter in the pic now.
    And that short harness that goes to the pressure sender, crank sensor, and rear knock sensor can stay with the engine?
    I actually can't get my meat mittens on the plug of the rear knock sensor to unplug it anyway.
    I should be about ready to pull it then. Just gotta tie up the PS and AC, and pull the converter bolts.
  10. #70 Re: How to pull an engine: BillBoost Style
    Rear knock sensor should be attached to the rear of the ps pump or hanging out close by. There's a connector about 12-18 from the knock sensor that they located right by the wheel well to make it easy. Problem is..most don't realize it's on the back of the ps pump and el ripppo
  11. #71 Re: How to pull an engine: BillBoost Style
    Mar 2015
    USA
    Two-Ton Hydraulic Engine Hoist: A handy tool for testing the tensile strength of ground straps, wiring harnesses, hydraulic clutch lines you may have forgotten to disconnect.
  12. #72 Re: How to pull an engine: BillBoost Style
    Earth
    Thanks for this Bill, had the engine out and in all in the same day.
    2001 Pontiac Grand Prix GTP
  13. #73 Re: How to pull an engine: BillBoost Style
    Happy you found it helpful
  14. #74 Re: How to pull an engine: BillBoost Style
    MINNESOTA
    If I was to pull my engine out, what parts would be good to replace while the engine is out
    Asking cause when I replace my headers I noticed a bolt broken on engine that holds the headers.
    Front of engine, by the radiator and when I did the seafoam cleaning I noticed it was leaking from there
    So I was thinking taking the engine out and drilling the broken bolt and tapping it
  15. #75 Re: How to pull an engine: BillBoost Style
    Rear main seal, rear cover gasket, oil pan gasket, crappy looking knock sensors, front cover gasket if leaking.
    Those would be the best things to do if you think they need to be done.
  16. #76 Re: How to pull an engine: BillBoost Style
    MINNESOTA
    Cool, thanks
    Doing theses myself, about how long do you think it will take me to pull the engine in/out
    I have another car that I can drive back and forth to work so not in a hurry
    I just want to make sure I replace parts that are kind of difficult when the engine is in
  17. #77 Re: How to pull an engine: BillBoost Style
    Apr 2015
    Columbus, OH
    Depends on how fast you can turn a wrench I suppose. Since you have another car, take your time and do it right. I like to clean and paint things as I go. I put a new radiator in, started friday night and finished yesterday afternoon. But I cleaned and painted the battery tray, and underneath it, painted the front support that has (had) all the factory stickers, and hit every bolt with the wire wheel.
    Top Swapped 01 Imp
  18. #78 Re: How to pull an engine: BillBoost Style
    MINNESOTA
    I do want to take my time and do it right
    Hopefully I can finish before winter gets here
  19. #79 Re: How to pull an engine: BillBoost Style
    Apr 2015
    Columbus, OH
    Quote Originally Posted by valente View Post
    Where you live, you better hurry! When's it start, end of July?
    Top Swapped 01 Imp
  20. #80 Re: How to pull an engine: BillBoost Style
    MINNESOTA
    Saint Paul
    Around the end of July(lol)
  1. Test BillBoost
    By BillBoost37 in forum Off Topic Discussion
    Last Post: 07-26-2011, 12:38 PM
  2. Thanks to Bio, Billboost, 01GTP, Reptile, Blue and others
    By Silver GTP in forum Shops and Community Heroes
    Last Post: 09-09-2010, 10:11 AM
  3. New headers after engine pull lots of noise
    By machinegunsquid in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-21-2010, 11:37 PM
  4. Engine and Trans pull... SAME TIME?
    By nathangartz in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-14-2009, 09:40 PM
  5. pull engine?????
    By kingd44 in forum Off Topic Discussion
    Last Post: 08-10-2008, 09:12 PM
