Thread: How to: Remove an axle
Results 1 to 20 of 120
  1. #1 Re: How to: Remove an axle
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    Quote Originally Posted by BillBoost37
    I think he wishes it was a little easier
    BINGO...I've never had to change an axle so doing it for the first time. I'm changing both because I can't tell which side is bad, the boots look fine, no grease spraying, etc. I was on here and also Googled till my fingers hurt, the symptom of vibrates on acceleration, smooth on coasting, and gets worse accelerating into a right turn. I found a half dozen posts on various forums with that exact symptom, and the cause was the same every time: bad axle, replaced it and vibration went away...but nobody said which side!!
    I'll stop overthinking this and dive into it tonight. Will follow your instructions to a tee and post back.
  2. #2 Re: How to: Remove an axle
    Jan 2021
    Ohio
    I know this is an old thread but did that fix the vibration on acceleration my car is doing that but I don't notice it so much turning it seems to do it straight when going straight but goes away when you let the gas off.
    However I also read that a motor mount could cause it and I read one time that control arm bushings can cause it I know the control arm bushings are bad on mine and I know the motor mount at the front of the motor is bad on mine it's leading down that side.
    Could control arm bushings and a motor mount also cause that vibration on acceleration? almost feels just like wheel balance.
  1. Possible Bad CV Axle?
    By mlasnoski in forum Brakes/Suspension/Chassis
    Last Post: 10-11-2011, 02:47 PM
  2. Is my axle going out?
    By guitarguyucf in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-26-2010, 07:05 AM
  3. axle
    By tylersgt in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-01-2010, 07:35 PM
  4. Grr. Axle Nut Size?
    By Gregorius in forum Brakes/Suspension/Chassis
    Last Post: 09-18-2009, 06:35 PM
  5. CV Axle
    By stlmo_gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-30-2008, 01:24 PM
