Thread: Simple Intake (pictures)
Page 14 of 23 FirstFirst ... 41213141516 ... LastLast
Results 261 to 280 of 454
  1. #261 Re: Simple Intake (pictures)
    the one side of the elbow is 4 inch o/d the other side is 3 inches.
    see how one side is fatter on the elbow.
  2. #262 Re: Simple Intake (pictures)
    Sep 2012
    St Louis Missouri
    i see. but if i get those exact products shown, my intake will fall off pretty easily? if so what are the correct types i should get to prevent my intake from falling off over time
    GTP Level Member dazedandconfused's Avatar
    Sep 2011
    bedford, Pa
    Quote Originally Posted by PioneerGTP View Post
    Mine is done with those exact products and only time it comes off is when I take it off.
    Sent from my iPhail
    97 gtp, cone filter mod, downpipe and glasspack to stock muffler mod, 180* t-stat mod, bad driver mod
  4. #264 Re: Simple Intake (pictures)
    Sep 2012
    St Louis Missouri
    alright thanks, ill probably do this tonight or tomorrow then.
  5. #265 Re: Simple Intake (pictures)
    the only thing you may want to change is the hose clamps that come with the rubber coupler and get 2 new ones from a auto parts store.
  6. #266 Re: Simple Intake (pictures)
    Sep 2012
    St Louis Missouri
    okay i keep hearing different things. is open cone a good idea or bad idea?
  7. #267 Re: Simple Intake (pictures)
    Open cone is a type of filter.
    Just make one like they have on here. Pick what style you want, its not going to be bad for the car.
  8. #268 Re: Simple Intake (pictures)
    Jan 2012
    Philadelphia
    what did all you 97 guys do with your large PCM? it doesn't like to fit where the factory air box is
  9. #269 Re: Simple Intake (pictures)
    Mar 2012
    NC
    Mine is now a vertical PCM standing on the plug held down by a bracket.
  10. #270 Re: Simple Intake (pictures)
    Jan 2012
    Philadelphia
    i want to find a way to make it look nice, this is mine as of now
    GXP Level Member Kolton Lock's Avatar
    Mar 2012
    Minneapolis MN
    My 98 has the overflow bottle behind the drivers headlight and the pcm is zip tied vertically to that lol sucks cause I have a 9 inch filter...
  12. #272 Re: Simple Intake (pictures)
    Mar 2012
    NC
    Mine is tucked tight to the rad support/coolant reservoir with a homemade bracket holding it down...it doesn't look bad surprisingly.
  13. #273 Re: Simple Intake (pictures)
    Jan 2012
    Philadelphia
    Quote Originally Posted by hitman92499 View Post
    can you PM me a pic when you get a chance, no rush
  14. #274 Re: Simple Intake (pictures)
    Mar 2012
    NC
    It'll be next weekend at earliest. I never took a pic of it because the wiring wasn't finished next to it.
  15. #275 Re: Simple Intake (pictures)
    GT Level Member RedneckGTP's Avatar
    Oct 2012
    Chelsea, MI
    cool. gonna give this a shot.
    been wanting to hear my SC more.
  16. #276 Re: Simple Intake (pictures)
    Donating User Odi's Avatar
    Chicago South Suburbs
    guys get rid of those corrugated hoses RIGHT AWAY.
  17. #277 Re: Simple Intake (pictures)
    bonnie guy proved that doesn't make a lick of difference at turdy-eight hundred power levels.
  18. #278 Re: Simple Intake (pictures)
    not my point, they look like absolute poopsicle.
  19. #279 Re: Simple Intake (pictures)
    Feb 2013
    Detroit, MI
    Thanks newarkk, I finally got mine done. I hope the image uploaded because im having a really hard time figuring out how to do it. It keeps telling me files are too large evn tho im doing it thru photoshop.
    Mine is a 2006..Also idk if I can mount the iat sensor in the pvc piping because then its before the maf sensor. Pardon my stupid queation but I didnt know if thatd be an issue because on the stock intake it was maf then the iat. My cone is a 4 inch so I couldn't switch them ariund as far as tb size and maf size. This is the only way it would work.
  20. #280 Re: Simple Intake (pictures)
    Arizona
    Quote Originally Posted by GrandPrix06GT View Post
    Thats because you need to copy the IMG CODE and then paste it with your reply no need to attach anything. your pic will show up just fine. As far as your IAT sensor it dosent matter post or pre maf but ideally youd want it close to the cone filter so it has the coldest air moving over it.
  1. simple trick.
    Last Post: 06-09-2013, 02:26 PM
  2. So simple yet A PITA
    By TorqueAutoMotiv in forum General Tech Discussion
    Last Post: 03-30-2010, 11:21 PM
  3. simple or not so simple
    By Ironwarrior in forum Canada
    Last Post: 07-04-2009, 06:00 PM
  4. fenderwell intake pictures
    By deft in forum 5.3L V8 (LS4)
    Last Post: 01-11-2008, 11:17 AM
