Thread: Simple Intake (pictures)
Page 14 of 21 FirstFirst ... 41213141516 ... LastLast
Results 261 to 280 of 419
  1. #1 Re: Simple Intake (pictures)
    Sep 2012
    St Louis Missouri
    so i need a filter, 3inch rubber coupler, a 4 inch and a 3 inch band clamp, and a 3 inch 45 elbow pvc pipe?
    nothing is like 3.5 to 4 inch or anything?
  2. #2 Re: Simple Intake (pictures)
    the one side of the elbow is 4 inch o/d the other side is 3 inches.
    see how one side is fatter on the elbow.
  3. #3 Re: Simple Intake (pictures)
    Sep 2012
    St Louis Missouri
    i see. but if i get those exact products shown, my intake will fall off pretty easily? if so what are the correct types i should get to prevent my intake from falling off over time
    GTP Level Member dazedandconfused's Avatar
    Sep 2011
    bedford, Pa
    Quote Originally Posted by PioneerGTP View Post
    Mine is done with those exact products and only time it comes off is when I take it off.
    Sent from my iPhail
    97 gtp, cone filter mod, downpipe and glasspack to stock muffler mod, 180* t-stat mod, bad driver mod
  5. #5 Re: Simple Intake (pictures)
    Sep 2012
    St Louis Missouri
    alright thanks, ill probably do this tonight or tomorrow then.
  6. #6 Re: Simple Intake (pictures)
    the only thing you may want to change is the hose clamps that come with the rubber coupler and get 2 new ones from a auto parts store.
  7. #7 Re: Simple Intake (pictures)
    Sep 2012
    St Louis Missouri
    okay i keep hearing different things. is open cone a good idea or bad idea?
  8. #8 Re: Simple Intake (pictures)
    Open cone is a type of filter.
    Just make one like they have on here. Pick what style you want, its not going to be bad for the car.
  9. #9 Re: Simple Intake (pictures)
    Jan 2012
    Philadelphia
    what did all you 97 guys do with your large PCM? it doesn't like to fit where the factory air box is
  10. #10 Re: Simple Intake (pictures)
    Mar 2012
    NC
    Mine is now a vertical PCM standing on the plug held down by a bracket.
  11. #11 Re: Simple Intake (pictures)
    Jan 2012
    Philadelphia
    i want to find a way to make it look nice, this is mine as of now
    GXP Level Member Kolton Lock's Avatar
    Mar 2012
    Minneapolis MN
    My 98 has the overflow bottle behind the drivers headlight and the pcm is zip tied vertically to that lol sucks cause I have a 9 inch filter...
  13. #13 Re: Simple Intake (pictures)
    Mar 2012
    NC
    Mine is tucked tight to the rad support/coolant reservoir with a homemade bracket holding it down...it doesn't look bad surprisingly.
  14. #14 Re: Simple Intake (pictures)
    Jan 2012
    Philadelphia
    Quote Originally Posted by hitman92499 View Post
    can you PM me a pic when you get a chance, no rush
  15. #15 Re: Simple Intake (pictures)
    Mar 2012
    NC
    It'll be next weekend at earliest. I never took a pic of it because the wiring wasn't finished next to it.
  16. #16 Re: Simple Intake (pictures)
    GT Level Member RedneckGTP's Avatar
    Oct 2012
    Chelsea, MI
    cool. gonna give this a shot.
    been wanting to hear my SC more.
  17. #17 Re: Simple Intake (pictures)
    Donating User Odi's Avatar
    Chicago South Suburbs
    guys get rid of those corrugated hoses RIGHT AWAY.
  18. #18 Re: Simple Intake (pictures)
    bonnie guy proved that doesn't make a lick of difference at turdy-eight hundred power levels.
  19. #19 Re: Simple Intake (pictures)
    not my point, they look like absolute poopsicle.
  20. #20 Re: Simple Intake (pictures)
    Feb 2013
    Detroit, MI
    Thanks newarkk, I finally got mine done. I hope the image uploaded because im having a really hard time figuring out how to do it. It keeps telling me files are too large evn tho im doing it thru photoshop.
    Mine is a 2006..Also idk if I can mount the iat sensor in the pvc piping because then its before the maf sensor. Pardon my stupid queation but I didnt know if thatd be an issue because on the stock intake it was maf then the iat. My cone is a 4 inch so I couldn't switch them ariund as far as tb size and maf size. This is the only way it would work.
  1. simple trick.
    Last Post: 06-09-2013, 02:26 PM
  2. So simple yet A PITA
    By TorqueAutoMotiv in forum General Tech Discussion
    Last Post: 03-30-2010, 11:21 PM
  3. simple or not so simple
    By Ironwarrior in forum Canada
    Last Post: 07-04-2009, 06:00 PM
  4. fenderwell intake pictures
    By deft in forum 5.3L V8 (LS4)
    Last Post: 01-11-2008, 11:17 AM
