Thread: Simple Intake (pictures)
Page 13 of 23 FirstFirst ... 31112131415 ... LastLast
Results 241 to 260 of 454
  1. #241 Re: Simple Intake (pictures)
    May 2012
    Tracy, California
    All right ill see
    Donating Users onetyme77's Avatar
    texas
    I've read over this thing several times and hear a few common problems. How do u stabilize the filter? Many have said the clamp will eventually get loose. And what schedule PVC should be used as it get very hot under the Hood? I dont want it warp or even worse melt.
    Tippy Tappin on Tapatalk with Sammy's S3
    Ohio
    Its not gonna warp or melt. I've had mine for 2 years with no problems
    texas
    Quote Originally Posted by 99pgpgt View Post
    How stable is it, how have ppl solved the issue of it becoming loose over time
    texas
    Quote Originally Posted by Asinity View Post
    Been a long time since I was on here, but have been scouting the site lately as I recently picked up a '99 GTP with 180,000km. Thanks for the how-to nawarkk, I used a K&N RU-1785 3.5x5x8.5" straight filter for mine, and man does the supercharger scream, absolutely love it.
    I'm thinking I'm going to need to pick up a new piece of PVC though, I bought one like yours, 3" with the small OD on the one side, however it seems the wall thickness on mine is a little thinner - the heat from the engine and the forces from the clamp seem to have turned it into an egg shape and the clamp had loosened off a little bit. I wonder has anyone else suffered from this problem? My engine temperature floats around the 85-90*C mark (185-194*F), which seems normal to me - granted I'm also using the boost a lot (really enjoying the car, lol) so I'm sure the supercharger is packing a heck of a lot more heat under the hood as well.
    His warped
  6. #246 Re: Simple Intake (pictures)
    use silicone joiner then.
    Also: if you have stock upper mounts, it'll move a lot, cause more elongating.
    texas
    Motor mounts?
  8. #248 Re: Simple Intake (pictures)
    The Boss Iceman6669's Avatar
    Jun 2011
    mine has been on for over a year right on the TB and has only came off when I took it off..... But as Matt says uppers are important... All I did to mine was flip them though.. Didnt go polly.
    2011 F-150 Yote powered
    Ohio
    Actually use the cement and primer for pvc joints.
    texas
    Quote Originally Posted by Iceman6669 View Post
    Flip the motor mounts? What does this accomplish. (Don want to get off topic, is there a thread with the answer/instructions? )
  11. #251 Re: Simple Intake (pictures)
    Jun 2011
    Just dont allow the motor to rock as much. Not as firm as polly mounts.. There might be a thread on it...
  12. #252 Re: Simple Intake (pictures)
    It's in the thread in both of our signatures.
    Read it.
    If you would do that you'd find the links on the How-To's
    texas
    Quote Originally Posted by blueguy91 View Post
    Read it.
    Can't see the sigs, don't have a laptop. Using my cell phone via tapatalk app
  14. #254 Re: Simple Intake (pictures)
    texas
    I apologize
  16. #256 Re: Simple Intake (pictures)
    GT Level Member GrandprixGT01's Avatar
    Nov 2011
    Keswick, Ontario
    Flipping the mounts is a nice easy mod. I never knew how much the motor moved on stock mounts until I followed this write up to make my CAI.
    2003 GT: Wizzair CAI, Flipped Dog Bones, MagnaFlow Mufflers, SE Exhaust Tips
  17. #257 Re: Simple Intake (pictures)
    May 2012
    Burlington, Wisconsin
    On a 98 GTP do I need to run the IAT or can I just strap on a filter to the TB and leave the IAT uninstalled?
    1998 GTP Sedan: Gen III, Speedy Daddy Headers, SLP Catback, Magnaflow High Flow Cat, Open Cone Intake, Autolite 104s, Debadged, more to come!
  18. #258 Re: Simple Intake (pictures)
    Kansas
    Be a boss... 4" aluminum 1/8" walled tubing... custom mount made from exhaust hanger. Something along the lines of this....
    The top part (exhaust pipe side) makes a nice little holding stand. Bend the long side at a 90* angle and bolt into existing hole from stock box. Or drill your own. Get it where you need it one clamp on the cone to tubing, and another for holding onto the stand. Found out the hard way if you use one clamp to hold em all, it would separate the cone from the tubing.
  19. #259 Re: Simple Intake (pictures)
    Sep 2012
    St Louis Missouri
    ignore
  20. #260 Re: Simple Intake (pictures)
    Sep 2012
    St Louis Missouri
    so i need a filter, 3inch rubber coupler, a 4 inch and a 3 inch band clamp, and a 3 inch 45 elbow pvc pipe?
    nothing is like 3.5 to 4 inch or anything?
  1. simple trick.
    Last Post: 06-09-2013, 02:26 PM
  2. So simple yet A PITA
    By TorqueAutoMotiv in forum General Tech Discussion
    Last Post: 03-30-2010, 11:21 PM
  3. simple or not so simple
    By Ironwarrior in forum Canada
    Last Post: 07-04-2009, 06:00 PM
  4. fenderwell intake pictures
    By deft in forum 5.3L V8 (LS4)
    Last Post: 01-11-2008, 11:17 AM
