Thread: Simple Intake (pictures)
Page 3 of 21 FirstFirst 1234513 ... LastLast
Results 41 to 60 of 419
  1. #1 Re: Simple Intake (pictures)
    GTX Level Member tayl5645's Avatar
    Jul 2010
    Michigan
    Will take some this weekend as I work. When i get everything spread out and as it goes in. The piping is already cut with the hole for the sensor. Its going to be interesting but when isnt it?
  2. #2 Re: Simple Intake (pictures)
    Windsor (ON) Canada
    Is there a "special" way to get the IAT off of the original air intake, I dont feel like cutting it out.
  3. #3 Re: Simple Intake (pictures)
    Pull it out?
  4. #4 Re: Simple Intake (pictures)
    West Side Michigan
    It doesn't pull out. What I would do is just put a nice simple slit with a knife from the outer edge, to the inner edge and try and wiggle it out. That way the stock pipping is not completely destroyed.
  5. #5 Re: Simple Intake (pictures)
    Uh mine just pulled out.
  6. #6 Re: Simple Intake (pictures)
  7. #7 Re: Simple Intake (pictures)
    West Side Michigan
    oh.. I couldn't pull mine out, it was surrounded by the rubber from the intake lol
    So I guess try pulling it out first then if that doesn't work do what I said.
  8. #8 Re: Simple Intake (pictures)
    Windsor (ON) Canada
    Quote Originally Posted by nawarkk View Post
    Trust me,, I tried pulling it right out, wasn't going anywhere...
    I'll try making a little slit in it. much appreciated
  9. #9 Re: Simple Intake (pictures)
    Windsor (ON) Canada
    Done and Done...
    Nice up-grade from my old intake.
  10. #10 Re: Simple Intake (pictures)
    West Side Michigan
    Quote Originally Posted by Colossus View Post
    Done and Done...
    Hook it up with a picture yo
  11. #11 Re: Simple Intake (pictures)
    Nov 2009
    Grand haven
    Clean your filter^^^^ it looks a lil rough.
  12. #12 Re: Simple Intake (pictures)
    Windsor (ON) Canada
    Quote Originally Posted by shawngtp View Post
    haha I HAVE cleaned it...the results of a past life of a FWI,
  13. #13 Re: Simple Intake (pictures)
    SE Level Member rmil03's Avatar
    Jun 2010
    jersey
    this work as good and effective as a k&n or something would? is there much of a hp gain?
    '01 gpgt, tinted tails, k&n custom intake, lime green engine bay, straight pipe exhaust, gold/black interior. dirrrrrtydir
  14. #14 Re: Simple Intake (pictures)
    Jun 2010
    jersey
    this work on an 01 gp gt? and is it that much better then the stock intake?
  15. #15 Re: Simple Intake (pictures)
    SE Level Member Ryansgtp's Avatar
    Jul 2010
    Medina NY
    Does the stock airbox just come right out? Do you have to keep any of it in there?
  16. #16 Re: Simple Intake (pictures)
    SE Level Member neyel8r's Avatar
    DFW TX
    i'm not sure which year you've got, but if it's an 04+, it should just pop right up & out, but you'll need to open up the airbox & remove the pcm on the bottom before pulling the airbox out. i removed mine without disconnecting anything, put some rubber underneath & zip tied it down where the airbox used to sit. hope i don't have any problems with that...
    anyway, my baby sounds a lot louder & feels better, but sometimes i hear some clicking or rattling from the engine while stepping on it... the filter isn't in contact with anything because i suspended it with a zip tie... any ideas what the noise could be?
  17. #17 Re: Simple Intake (pictures)
    Jul 2010
    Medina NY
    Quote Originally Posted by neyel8r View Post
    Ya mine makes the same noise. But only when I just start going normal speed, until I get to like 25mph. I know their is supposed to be a suction sound but is there supposed to be a rattle too
  18. #18 Re: Simple Intake (pictures)
    DFW TX
    Quote Originally Posted by Ryansgtp View Post
    i read in another forum somewhere about a dude who now hears a "rattlesnake" sound in the engine after doing a mod like this, which is just like what i hear at lower rpm's. it usually goes away before i hit 2nd, sometimes 3rd, but i really only hear it when i jump on the gas. i can only hope that's what the open cone intake is supposed to sound like...
    seems to make sense though, like the filter is gasping in air in shorter bursts which sound like a rattlesnake at first, which increases with the rpms & tapers off into a roaring suction sound when the airflow & rpms are higher... idk, never heard anything like it before i took the airbox out... i'm not sure about the rattle, but the rest of it sounds great
    edit: i might have a bad seal... i twisted the cone a bit, which seemed to help some with the rattling, but it's not gone. i'm gonna need to add some silicone sealant between the base of the cone and the connecting flange.
    '05 GT - open cone intake, 80w xenons, ceramic harnesses, LED front signals\interiors\reverse lights, tint & stereo soon, the rest stock... for now
  19. #19 Re: Simple Intake (pictures)
    Jul 2010
    Medina NY
    You were right man. I went out and retightened everything up and now you can only hear suction. Musta came a lil loose after drivin it. THANKS A LOT. I LOVE THIS FORUM, its so helpful. I appreciate it bud
  20. #20 Re: Simple Intake (pictures)
    DFW TX
    well, weirdly enough, it stopped bothering me after a while & i never got around to sealing it up like i was going to. the "rattlesnake" sounded kinda intimidating or something... so i left it alone.
    but it started bothering me again today so i just popped the hood & made some adjustments. gonna go pick up a burger & test it out.
    btw, although i never got to it myself, i'm glad i could help you with the idea!
    Quote Originally Posted by chamilton89 View Post
    I just installed my new intake a few weeks ago and within a week it started throwing a check engine light at me. Took it to get looked at and as it turns out the oiled filters do terrible things to the MAF, im thinking about just taking the damn thing off unless anyone has any good ideas on how to resolve this issue.
    i believe you because i've heard elsewhere of that being a problem...... i would suggest removing & cleaning it, followed by replacing your intake with a dry one. search the forums about how to clean the MAF.
  1. simple trick.
    Last Post: 06-09-2013, 02:26 PM
  2. So simple yet A PITA
    By TorqueAutoMotiv in forum General Tech Discussion
    Last Post: 03-30-2010, 11:21 PM
  3. simple or not so simple
    By Ironwarrior in forum Canada
    Last Post: 07-04-2009, 06:00 PM
  4. fenderwell intake pictures
    By deft in forum 5.3L V8 (LS4)
    Last Post: 01-11-2008, 11:17 AM
