Thread: Simple Intake (pictures)
Page 20 of 21 FirstFirst ... 1018192021 LastLast
Results 381 to 400 of 419
  1. #381 Re: Simple Intake (pictures)
    Oct 2013
    michigan
    yes I do but there was no definitive markings on it denoting size. and thanks!
    01 gtp SD headers. gen V swap. hai. zzp 1.0 pcm. 06 Impala brakes. GMPP sway bar.
    01 ram 2500 870hp/1796lbft fmw s467.7 w/n20 old. new 66/86 compounds ????hp/????lbft.
  2. #382 Re: Simple Intake (pictures)
    Donating Users EHB's Avatar
    Dec 2014
    Maryland
    has anyone tried using silicone to help hold the cone to the pvc ?
    2000 GTP - 3" Catted DP...ZZP Plog...9" Cone filter...Reptile pcm...3.4 pulley...AL104's
  3. #383 Re: Simple Intake (pictures)
    Dec 2014
    Maryland
    just installed the nawarkk air intake system. i used a 3inch coupler i found in the plumbing section instead of the one nawarkk used. it was about 1/4 thick rubber. fought for a half hour trying to strtch it over the throttle body. kept hearing a voice saying "use your man arms ! " . tried lubing it with vasoline and still couldn't get it. just as i was about to give up and go look for a larger diameter coupling , i loosened the clamp up a little more and it slid right on .....guess sometimes using your brain trumps using man arms.
    the coupler was 4 inches long and made a perfect spot to drill a half inch hole to snug the IAT sensor in.
    anywho , after i tightened everything up and getting psyched expecting some changes in sound and/or performance , i started the car . i heard nothing. nothing different anyway. there was no big suction noise or anything different that i could here.took her for about 8 mile trip , mashing the throttle often. i did notice the whine was a bit louder than it was at WOT, but not a big difference. i think the throttle response was a little better but i did put new iridium plugs , wires and a new O2 sensor in yesterday as well.
    my next step is to knock the dino oil out and put a new K&N Oil filter and some mobile 1 synthetic in it.
  4. #384 Re: Simple Intake (pictures)
    lol, because the throttle body is bigger than 3".
    The pipe coupler was 3".
  5. #385 Re: Simple Intake (pictures)
    Dec 2014
    Maryland
    it wasn't the coupler that wasn't big enough for the TB , it was the clamp that wouldn't slide over it. it was one of these deals that already had the clamps in place and i had them loose...just not loose enough to go over the lip on the TB.
    Simple Intake (pictures) Attached Images
  6. #386 Re: Simple Intake (pictures)
    Or, you just bolt the filter on the throttle body like 99% of everyone does because it's simpleR and it works.
  7. #387 Re: Simple Intake (pictures)
    Dec 2014
    Maryland
    you see i asked about doing that in the noob intro forum and all i got was some smart ass replies and a debate about cai vs hai. not one person chimed in and said thats how they run their filter.
    http://www.grandprixforums.net/threa...Question/page2
    edit - the last poster said he runs it that way.
  8. #388 Re: Simple Intake (pictures)
    Because basically there were two people posting in there that actually were helping you.
    If you're worried about it, try different setups. Get the tubing, install it. Then remove it and bolt the filter to the throttle body. It's not going to be any different either way like they stated. The cone on the TB will just make the blower louder at WOT, throttle response might be a little better too.
    I do it that way because I'm lazy, it's easy, and the gains for all the extra work with intake piping don't warrant my time.
    How's that?
  9. #389 Re: Simple Intake (pictures)
    Dec 2014
    Maryland
    Quote Originally Posted by blueguy View Post
    How's that?
    this is the kind of answer i was looking for. not, "do what you want".
  10. #390 Re: Simple Intake (pictures)
    Donating User
    Jul 2014
    Minnesota
    Hey thanks for the write up nawarkk, i finished mine last weekend and I could not be happier. The increased engine noise was well worth it by it self but the increased acceleration I feel is awesome.
    I still do not know how to post pictures directly so here is a link
    http://s3.postimg.org/m1mr4jm8z/IMAG0220.jpg
    00 Red GT - ZZP PCM, ZZP HV TB, TRANSGO kit, GMPP Sway Bars, Strut Tower Braces,
  11. #391 Re: Simple Intake (pictures)
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by 00RedfireGT View Post
    Just put [IMG] in front of your URL, and [/IMG] after it.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  12. #392 Re: Simple Intake (pictures)
    it me, or does that pipe look small?
  13. #393 Re: Simple Intake (pictures)
    Kemmerer, Wyoming
    I think you are too used to looking at small things scott
  14. #394 Re: Simple Intake (pictures)
    no im used to looking at large things lol
    thats a 2 inch pipe. see how tight the clamp is next to the one on the tb.
  15. #395 Re: Simple Intake (pictures)
    Jul 2010
    Coquitlam,BC,Canada
    Big hands make everything look small.
    Yer right Scotty. Must be one of them new power-reducing intakes. LOL
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  16. #396 Re: Simple Intake (pictures)
    Dec 2014
    Maryland
    Quote Originally Posted by ScottyDoggs View Post
    it;s an optical illusion created by the scratch on the pipe that makes it look like the edge of the tubing...look at the iat sensor.
  17. #397 Re: Simple Intake (pictures)
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by EHBGoober View Post
    Damn! Good eye.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  18. #398 Re: Simple Intake (pictures)
    Dec 2014
    Maryland
    lol..at first i was like ? then i realized part of the tubing was blending in with the black in the back ground..plus i have a 27 inch monitor so the picture is really big..lol
  19. #399 Re: Simple Intake (pictures)
    Donating User
    Jul 2014
    Minnesota
    Thanks Scotty for posting the picture. It is the correct size pipe for all of those who are questioning it. This is a great mod.
  20. #400 Re: Simple Intake (pictures)
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    4" intake ftmfw(ill paint the tube black one day)
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  1. simple trick.
    Last Post: 06-09-2013, 02:26 PM
  2. So simple yet A PITA
    By TorqueAutoMotiv in forum General Tech Discussion
    Last Post: 03-30-2010, 11:21 PM
  3. simple or not so simple
    By Ironwarrior in forum Canada
    Last Post: 07-04-2009, 06:00 PM
  4. fenderwell intake pictures
    By deft in forum 5.3L V8 (LS4)
    Last Post: 01-11-2008, 11:17 AM
