Thread: 04+ Rack and Pinion replacement [*]
Results 1 to 20 of 66
  1. #1 Re: 04+ Rack and Pinion replacement [*]
    GTX Level Member Bills1997GTP's Avatar
    Oct 2012
    Philadelphia
    Not to bring up an old thread, is there another link for a writeup?
    2004 Grand Prix GTP 150,000 " The New Edition "
  2. #2 Re: 04+ Rack and Pinion replacement [*]
    I don't have a write up...but check me out.
    Jack and support car (usually at factory jacking locations right behind front wheels.
    Remove both wheels
    Remove the nuts holding the tie rods to knuckles and free tie rods from knuckles
    Ensure steering wheel is straight and can not turn
    Lift rubber boot on top of rack and unbolt the 11mm holding the telescoping shaft to the rack. Wiggle it free
    Lower rear of subframe about 2-3 inches and support at that height
    Disconnect the two ps pump lines at the rack
    Remove two bolts holding rack to subframe
    Slide rack out the wheel well and reverse for installation.
    Once completed, start car and fill ps res.
    Turn wheel a few times in both directions an allow system to bleed air out.
    Repeat with fluid/turning and sitting until system is at the correct level and not making noise.
    this is about all you need to know short of pics. google will find a few more that are on other boards, some with pics, most w/o.
    Quote Originally Posted by Bills1997GTP View Post
  1. CV Shaft Replacement [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 01-05-2012, 09:22 AM
  2. Really Nice Rack!
    By FastKatt in forum Off Topic Discussion
    Last Post: 04-05-2008, 04:22 AM
  3. PVC Valve Replacement (L67) [*]
    By 03GPScottyd in forum How To Write-Ups/Tech Tips
    Last Post: 02-18-2008, 06:43 PM
  4. Valve Spring replacement...
    By Iron Indian in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-01-2008, 07:30 PM
  5. PCV Valve Replacement (L36) [*]
    Last Post: 01-03-2008, 11:25 PM
