Thread: 04+ Rack and Pinion replacement [*]
Results 21 to 40 of 66
UR LOSN 04+ Rack and Pinion... 04-06-2008, 05:13 AM
SyntheticShield Re: 04+ Rack and Pinion... 04-06-2008, 10:52 AM
UR LOSN Re: 04+ Rack and Pinion... 04-06-2008, 04:26 PM
UR LOSN Re: 04+ Rack and Pinion... 04-06-2008, 04:28 PM
trishieldfan Re: 04+ Rack and Pinion... 04-06-2008, 10:30 PM
SyntheticShield Re: 04+ Rack and Pinion... 04-07-2008, 12:00 AM
UR LOSN Re: 04+ Rack and Pinion... 04-07-2008, 04:27 AM
Sinister Drag Designs Re: 04+ Rack and Pinion... 04-19-2008, 06:50 PM
FastKatt Re: 04+ Rack and Pinion... 12-21-2008, 10:38 PM
carl06GT Re: 04+ Rack and Pinion... 01-24-2009, 03:18 PM
FastKatt Re: 04+ Rack and Pinion... 01-24-2009, 05:26 PM
tommy123 Re: 04+ Rack and Pinion... 01-09-2010, 04:09 PM
chevy man Re: 04+ Rack and Pinion... 01-28-2010, 11:11 PM
brennhm Re: 04+ Rack and Pinion... 01-02-2012, 09:15 PM
mudhunter Re: 04+ Rack and Pinion... 01-10-2012, 01:02 PM
BillBoost37 Re: 04+ Rack and Pinion... 01-10-2012, 01:33 PM
mudhunter Re: 04+ Rack and Pinion... 01-10-2012, 01:50 PM
BillBoost37 Re: 04+ Rack and Pinion... 01-10-2012, 02:20 PM
atomicjoe23 Re: 04+ Rack and Pinion... 07-28-2012, 07:31 PM
penright Re: 04+ Rack and Pinion... 07-31-2013, 07:34 AM
brised Re: 04+ Rack and Pinion... 10-10-2013, 11:13 AM
Scottydoggs Re: 04+ Rack and Pinion... 10-10-2013, 11:16 AM
Scottydoggs Re: 04+ Rack and Pinion... 07-31-2013, 08:59 AM
penright Re: 04+ Rack and Pinion... 07-31-2013, 09:38 AM
Scottydoggs Re: 04+ Rack and Pinion... 07-31-2013, 10:59 AM
91parkave Re: 04+ Rack and Pinion... 07-31-2013, 12:25 PM
Scottydoggs Re: 04+ Rack and Pinion... 07-31-2013, 12:27 PM
Bills1997GTP Re: 04+ Rack and Pinion... 09-21-2013, 04:06 PM
Scottydoggs Re: 04+ Rack and Pinion... 09-21-2013, 04:29 PM
Bills1997GTP Re: 04+ Rack and Pinion... 09-22-2013, 12:08 PM
Scottydoggs Re: 04+ Rack and Pinion... 09-22-2013, 12:15 PM
91parkave Re: 04+ Rack and Pinion... 09-22-2013, 02:47 PM
brised Re: 04+ Rack and Pinion... 10-11-2013, 07:19 AM
MGRead Re: 04+ Rack and Pinion... 11-17-2013, 08:24 PM
April Thompson Re: 04+ Rack and Pinion... 01-02-2015, 12:12 PM
CW2Lido Re: 04+ Rack and Pinion... 02-22-2015, 01:05 AM
Tross901 Re: 04+ Rack and Pinion... 06-02-2015, 10:49 AM
stealthee Re: 04+ Rack and Pinion... 06-02-2015, 11:00 AM
HighOctaneRacing Re: 04+ Rack and Pinion... 06-02-2015, 07:44 PM
stocker Re: 04+ Rack and Pinion... 12-01-2016, 05:06 PM
Scottydoggs Re: 04+ Rack and Pinion... 12-01-2016, 05:12 PM
brised Re: 04+ Rack and Pinion... 12-02-2016, 07:03 AM
Swiggles Re: 04+ Rack and Pinion... 12-03-2016, 06:56 PM
Scottydoggs Re: 04+ Rack and Pinion... 12-03-2016, 07:13 PM
stealthee Re: 04+ Rack and Pinion... 12-03-2016, 07:34 PM
Scottydoggs Re: 04+ Rack and Pinion... 12-03-2016, 07:53 PM
HighOctaneRacing Re: 04+ Rack and Pinion... 12-03-2016, 11:39 PM
Scottydoggs Re: 04+ Rack and Pinion... 12-04-2016, 09:05 AM
Tonkin2000GT Re: 04+ Rack and Pinion... 12-04-2016, 09:34 AM
Scottydoggs Re: 04+ Rack and Pinion... 12-04-2016, 10:05 AM
Swiggles Re: 04+ Rack and Pinion... 12-04-2016, 10:03 PM
Tonkin2000GT Re: 04+ Rack and Pinion... 12-04-2016, 10:04 PM
Scottydoggs Re: 04+ Rack and Pinion... 12-04-2016, 10:15 PM
Tonkin2000GT Re: 04+ Rack and Pinion... 12-04-2016, 10:18 PM
Scottydoggs Re: 04+ Rack and Pinion... 12-04-2016, 10:32 PM
Tonkin2000GT Re: 04+ Rack and Pinion... 12-04-2016, 10:33 PM
CHI2000GTP Re: 04+ Rack and Pinion... 03-31-2017, 01:17 PM
Scottydoggs Re: 04+ Rack and Pinion... 03-31-2017, 01:20 PM
CHI2000GTP Re: 04+ Rack and Pinion... 03-31-2017, 01:29 PM
Scottydoggs Re: 04+ Rack and Pinion... 03-31-2017, 01:31 PM
CHI2000GTP Re: 04+ Rack and Pinion... 03-31-2017, 02:51 PM
chenango kid Re: 04+ Rack and Pinion... 08-11-2017, 10:07 PM
Dr Cedric Re: 04+ Rack and Pinion... 09-24-2017, 12:51 AM
Scottydoggs Re: 04+ Rack and Pinion... 09-24-2017, 06:39 AM
Dr Cedric Re: 04+ Rack and Pinion... 09-25-2017, 07:28 PM
rickisrad Re: 04+ Rack and Pinion... 09-26-2017, 01:31 PM
  1. #1 Re: 04+ Rack and Pinion replacement [*]
    May 2012
    Hubbardston, MA
    Advance Auto Parts sells a boot or cover for less than $4. Don't use it unless you are removing the Rack. It is very flexible but impossible to replace with the Rack in the car.
    The more expensive boots are rigid and can be installed without breaking or bending hydraulic lines.
    I broke the return line when trying to install the flimsy boot. I ended up buying the better boot along with a new return line. I spent a whole day redoing it.
    Take my advise and buy the stiffer boot.
  2. #2 Re: 04+ Rack and Pinion replacement [*]
    Quote Originally Posted by brised View Post
    you can replace the dust boots with it on the car, how do you think you change a inner tie rod? yup the boot has to come off, been there, done that.
  3. #3 Re: 04+ Rack and Pinion replacement [*]
    i haven't heard of any one re building their old rack, most of us tend to just swap it.
    not that it cant be done. but i have not found a rebuild how to either.
  4. #4 Re: 04+ Rack and Pinion replacement [*]
    GT Level Member penright's Avatar
    Mar 2013
    United States
    It's my 06 and the granddaughter's 06 that has the leak. Leak may be strong, the boot is just moist. If it was the project car, I be doing it in a heartbeat, that the whole purpose of it. I wonder how close a 97's rack and pinion is to 06's? The PS fluid was low in the 97 when I bought it, maybe I could practice on it first? Then I could report back. :-) None of the three are variable steering. I think only my GXP is.
    07 Grand Prix GXP (My Daily Driver and future toy) (120,000+)
    97 Grand Prix GT (Project Car) (178,000+)
    02 Mustang Convertible (Wife's Toy) (75,000+)
    17 Honda Civic (Wife's Daily Driver)
  5. #5 Re: 04+ Rack and Pinion replacement [*]
    it should be the same job 97 -08. if it has magnasteer there will be a wire from the rack where the column boot is. it leads up towards the tranny.
    a 18 mm line wrench makes getting the lines off the rack easy too.
  6. #6 Re: 04+ Rack and Pinion replacement [*]
    Arizona
    Regardless unhooking those lines is the biggest PITA. You will love how GM gives you just enough room to make you think the job wont be that bad.
  7. #7 Re: 04+ Rack and Pinion replacement [*]
    after lowering the rack a few inches, i took the lines off, from under the car, even with my huge 3x wearing gloves hands there was plenty of room to get the lines off.
  8. #8 Re: 04+ Rack and Pinion replacement [*]
    GTX Level Member Bills1997GTP's Avatar
    Oct 2012
    Philadelphia
    Not to bring up an old thread, is there another link for a writeup?
    2004 Grand Prix GTP 150,000 " The New Edition "
  9. #9 Re: 04+ Rack and Pinion replacement [*]
    I don't have a write up...but check me out.
    Jack and support car (usually at factory jacking locations right behind front wheels.
    Remove both wheels
    Remove the nuts holding the tie rods to knuckles and free tie rods from knuckles
    Ensure steering wheel is straight and can not turn
    Lift rubber boot on top of rack and unbolt the 11mm holding the telescoping shaft to the rack. Wiggle it free
    Lower rear of subframe about 2-3 inches and support at that height
    Disconnect the two ps pump lines at the rack
    Remove two bolts holding rack to subframe
    Slide rack out the wheel well and reverse for installation.
    Once completed, start car and fill ps res.
    Turn wheel a few times in both directions an allow system to bleed air out.
    Repeat with fluid/turning and sitting until system is at the correct level and not making noise.
    this is about all you need to know short of pics. google will find a few more that are on other boards, some with pics, most w/o.
    Quote Originally Posted by Bills1997GTP View Post
  10. #10 Re: 04+ Rack and Pinion replacement [*]
    Oct 2012
    Philadelphia
    Do you know what tools I'd be needing, I was going to pay somebody to do it but i changed my mind lol
  11. #11 Re: 04+ Rack and Pinion replacement [*]
    a 18 mm line wrench is nice to have for the lines to the rack. the rest all you need is a 30 piece socket set from lowes or home depot. and some open end/box wrenches and a hammer of some sort to pop the tie rod ends from the knuckle. a normal roofing type hammer will work, but a baby 5 lb sledge will work better.
    and if you have say a foot or more of extensions it will make getting the bolt off the intermediate shaft a lot easier. ( the bolt under the boot)
  12. #12 Re: 04+ Rack and Pinion replacement [*]
    Arizona
    ^^^this plus a decent flathead screwdriver to pry apart the piece where the 11mmbolt goes
  13. #13 Re: 04+ Rack and Pinion replacement [*]
    May 2012
    Hubbardston, MA
    Of course you can change the boot and the inner and outer Tie Rods without removing the rack.
    My post referred to the BOOT. I replaced both the inner and outer Tie Rod. I bought a cheap boot FOR $4 and could not get it on. I broke more **** trying to install it . (THE RACK WAS NEVER REMOVED.)
    The job took a lot longer because I had to replace the Power Steering return line after I broke it.
    The more expensive boot is rigid and does not require a contortionist to install it. The extra $40 for the better boot is well worth it. It is rigid and slides right in place.
  14. #14 Re: 04+ Rack and Pinion replacement [*]
    SE Level Member MGRead's Avatar
    Jun 2012
    Coral Spring, Fl
    link on post 1 not working
  15. #15 Re: 04+ Rack and Pinion replacement [*]
    GT Level Member April Thompson's Avatar
    Dec 2014
    Moline, IL
    I used to have an '89 that went through two racks... and in both cases they blew their seals and the steering fluid came pouring out of the right side!
    2004 Grand Prix GT2-clone A.K.A. the "Cybercar;" Galaxy Silver; 146K miles; RETROFITS: leather-wrapped steering wheel (w/audio controls) & shift knob; trip computer; map lights & dual lighted vanity visors; heated (?) leather seats w/ 10-way power driver's seat; ​HUD conversion
  16. #16 Re: 04+ Rack and Pinion replacement [*]
    SE Level Member CW2Lido's Avatar
    Pearl City Hawaii
    I removed my exhaust down pipe to make it a little easier to get the rack out and access the power steering line fittings. And dropping the cradle does make a world of difference and allows you to clean all your power steering fluid and road grime off the back of the engine area. I found it rather fun to get in there and clean up many years of grime. It also helped me check my power steering lines for corrosion. Found the return line will need to be changed out in a year or two.
    I don't know the percentage of Grand Prix's with the Magnasteer rack, but the difference is when you are at idle the car senses it needs more assistance to steer and some how it gives you that extra umpf. I changed one in a 2002 GTP and in my 2006 GXP, very similar on how to swap it out.
    My 06 GXP had no steering assist at all when the car was at idle but when I gave the car some gas all of a sudden it would work, and there was a slow leak coming from the rack on the outside boots. I was at the auto recycling center when I came upon a 2007 Grand Prix base line model with what appeared to be a refurbished rack. It had the tag on it, was freshly painted black and in great shape, plus it was magnasteer. The car looked as it if had been near a fire due to the paint all burnt up on one side. I purchased the rack for 35 dollars and it works great. I also replaced my power steering pump since I had the motor out of the car to replace exhaust bolts (broken in the head) and rear main oil seal.
  17. #17 Re: 04+ Rack and Pinion replacement [*]
    Jun 2015
    Walker, Michigan
    How do you get the new rack knob to line up with the steering shaft on the new unit?
  18. #18 Re: 04+ Rack and Pinion replacement [*]
    SWPA
    Place them side by side before you reinstall and make sure it is turned the proper way. You can turn it with pliers.
  19. #19 Re: 04+ Rack and Pinion replacement [*]
    Enfield, CT
  20. #20 Re: 04+ Rack and Pinion replacement [*]
    GTP Level Member
    Aug 2012
    st louis park, MN
    Am I the only one that the link doesn't work for in the first post?
    2008 Grand Prix Base: Engine cover delete , flipped dogbone bushings, Transgo shift kit, Hayden 403 trans cooler,
    Quote Originally Posted by Yarbeau View Post
    we are all anal about our vehicles. Otherwise we would not be on an extinct platforms forum debating 3000 dollars cars!
  1. CV Shaft Replacement [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 01-05-2012, 09:22 AM
  2. Really Nice Rack!
    By FastKatt in forum Off Topic Discussion
    Last Post: 04-05-2008, 04:22 AM
  3. PVC Valve Replacement (L67) [*]
    By 03GPScottyd in forum How To Write-Ups/Tech Tips
    Last Post: 02-18-2008, 06:43 PM
  4. Valve Spring replacement...
    By Iron Indian in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-01-2008, 07:30 PM
  5. PCV Valve Replacement (L36) [*]
    Last Post: 01-03-2008, 11:25 PM
