Thread: 04+ Rack and Pinion replacement [*]
Results 41 to 60 of 66
  1. #41 Re: 04+ Rack and Pinion replacement [*]
    its a old link left over from the old site, it dont work no more.
  2. #42 Re: 04+ Rack and Pinion replacement [*]
    May 2012
    Hubbardston, MA
    None of the links work anymore.
  3. #43 Re: 04+ Rack and Pinion replacement [*]
    Quincy, Mass
    Should be about the same as an 97-03 rack install. You have to lower the subframe to get it out, easiest is to drop the whole subframe in my opinion
    No more GP 04 Impala SS Indy:
  4. #44 Re: 04+ Rack and Pinion replacement [*]
    what you smoking up there swiggy? lower the rear of the frame a few inches. take rack out, rather simple. theres vids on you tube, they use a lift, but the same thing gets done on jack stands.
  5. #45 Re: 04+ Rack and Pinion replacement [*]
    SWPA
    Yeah, I'm thinking the same thing. Its really not hard at all to do with just lowering the rear a few inches.
  6. #46 Re: 04+ Rack and Pinion replacement [*]
  7. #47 Re: 04+ Rack and Pinion replacement [*]
    Enfield, CT
    I thought you pulled the rack without lowering the subframe Scotty?
    Sent from my VS985 4G using Tapatalk
  8. #48 Re: 04+ Rack and Pinion replacement [*]
    ive heard tails of it coming out with out lowing the frame. seems like bs to me, cause you cant really get to its bolts unless you drop it some.
  9. #49 Re: 04+ Rack and Pinion replacement [*]
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    I've changed my rack twice without lowering the subframe you just take out the sway bar it really wasn't that bad especially the second time around lol
    Sent from my SM-G920V using Tapatalk
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  10. #50 Re: 04+ Rack and Pinion replacement [*]
    and i lower the frame to get the sway bar off too lol the brake lines block the rear cap bolt, putting a socket through the rusty brake lines really seems like a bad idea to me.
    in that pic you can se how tight they are on a 98 at least, i hear they got more room on newer years.
  11. #51 Re: 04+ Rack and Pinion replacement [*]
    Quincy, Mass
    You take it out from the side? That's much easier lol. First time I saw it done was on a lift and the subframe was just about off. The second time I did it myself at bills with frame off, but we may have been doing other things on the frame too now that I think back 4 years ago.
  12. #52 Re: 04+ Rack and Pinion replacement [*]
    Jul 2015
    Jamestown, NY
    Yea it'll slide out the passenger side.
  13. #53 Re: 04+ Rack and Pinion replacement [*]
    out the driver side is easier, requires a twist and rotation act lol
    at bills house frame off, im leaning towards a tranny swap.
  14. #54 Re: 04+ Rack and Pinion replacement [*]
    Jul 2015
    Jamestown, NY
    Lol I didnt want to mess up my lines so I went out the passenger side. What about your tranny?
  15. #55 Re: 04+ Rack and Pinion replacement [*]
    tranny's f ing great! im up to 40 mile or so now.
  16. #56 Re: 04+ Rack and Pinion replacement [*]
    Jul 2015
    Jamestown, NY
    Nice good for you man
  17. #57 Re: 04+ Rack and Pinion replacement [*]
    GTP Level Member CHI2000GTP's Avatar
    Dec 2015
    Chicago, IL
    I'm at my car right now, working on removing the rack... that steering shafts boot is not sliding anywhere. It's rigid as hell. Do I jam a huge screw driver up into it and break it off? And then buy a replacement? It already started cracking from me trying to move it.
    2000 GTP 4DR - Stock
    243,000 miles
    CHICAGO, IL
    My Car: http://www.grandprixforums.com/members-rides/103740-lukes-gtp.html#post1443981
  18. #58 Re: 04+ Rack and Pinion replacement [*]
    lower the frame some, should make it pry off easier. that boot goes up through the firewall to the column, you dont want to replace it.
  19. #59 Re: 04+ Rack and Pinion replacement [*]
    Dec 2015
    Chicago, IL
    Alright. I'll lower the subframe first. Seems like it's not gonna budge tho. Back to work
    243,000 miles
    CHICAGO, IL
  20. #60 Re: 04+ Rack and Pinion replacement [*]
    once you got some tension on it, run a screw driver around the edge and work it off.
  1. CV Shaft Replacement [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 01-05-2012, 09:22 AM
  2. Really Nice Rack!
    By FastKatt in forum Off Topic Discussion
    Last Post: 04-05-2008, 04:22 AM
  3. PVC Valve Replacement (L67) [*]
    By 03GPScottyd in forum How To Write-Ups/Tech Tips
    Last Post: 02-18-2008, 06:43 PM
  4. Valve Spring replacement...
    By Iron Indian in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-01-2008, 07:30 PM
  5. PCV Valve Replacement (L36) [*]
    Last Post: 01-03-2008, 11:25 PM
