Thread: 04+ Rack and Pinion replacement [*]
Page 4 of 4 FirstFirst ... 234
Results 61 to 66 of 66
  1. #61 Re: 04+ Rack and Pinion replacement [*]
    GTP Level Member CHI2000GTP's Avatar
    Dec 2015
    Chicago, IL
    Got it. All good. Didn't realize it was right there, only about .75in up the shaft.
    2000 GTP 4DR - Stock
    243,000 miles
    CHICAGO, IL
    My Car: http://www.grandprixforums.com/members-rides/103740-lukes-gtp.html#post1443981
  2. #62 Re: 04+ Rack and Pinion replacement [*]
    dutchess county,n y
    hey all
    I have play in what seems like the Rack itself like scotty said slop in the rack . but I was thinking could it be in the intermediate shaft . before I pulled the tranny and frame there was no play at all .
  3. #63 Re: 04+ Rack and Pinion replacement [*]
    Jul 2013
    Phoenix
    Im in the middle of this project. Got everything disconnected, but now I'm having a hard time getting the Pinion to slide back up into the steering linkage u-joint. Any tips or tools that can get everything to slide back in? Do I need to grease them up? Somehow pry the ujoint part open a bit? Thanks for any help!
  4. #64 Re: 04+ Rack and Pinion replacement [*]
    you should already have the rear sub frame lowered, so pull the shaft down as far as it will go, then jack the frame up to it. easiest way ive found to get that damn thing back on.
  5. #65 Re: 04+ Rack and Pinion replacement [*]
    Jul 2013
    Phoenix
    Update:
    Got the rack and pinion back in, connected everything, and got it realigned. So far so good (but only a day into it.) We'll see how the driveway looks tomorrow morning!
  6. #66 Re: 04+ Rack and Pinion replacement [*]
    GTP Level Member
    Jun 2016
    Cleveland ohio
    I have always used a small pry bar or screwdriver to open it more. Usually slides right in after that.
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  1. CV Shaft Replacement [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 01-05-2012, 09:22 AM
  2. Really Nice Rack!
    By FastKatt in forum Off Topic Discussion
    Last Post: 04-05-2008, 04:22 AM
  3. PVC Valve Replacement (L67) [*]
    By 03GPScottyd in forum How To Write-Ups/Tech Tips
    Last Post: 02-18-2008, 06:43 PM
  4. Valve Spring replacement...
    By Iron Indian in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-01-2008, 07:30 PM
  5. PCV Valve Replacement (L36) [*]
    Last Post: 01-03-2008, 11:25 PM
