Thread: Blend Door Actuator Replacement
Results 1 to 20 of 90
  1. #1 Re: Blend Door Actuator Replacement
    SE Level Member LilJoe's Avatar
    Nov 2010
    Mariposa
    i have same issues first some idiot toke out the fuse for the hvac put 1 in started working than a few weeks later started messing up and than i started hearing this werid ticking noise when the a/c was off than found a alil hole in a vac line replaced that it blew faster but still got that same problem
    1998GTP
  2. #2 Re: Blend Door Actuator Replacement
    SE Level Member TomOfTarsus's Avatar
    Nov 2009
    near Pittsburgh, PA
    Is there a write-up for the actuator or linkage that connects to the defrost/dash/floorboard selector switch? Mine is broke and I've been all around looking for some tips. Home from work today because I couldn't see to drive!
    Thanks,
    Tom
  3. #3 Re: Blend Door Actuator Replacement
    that part works on vacuum, check for a leak under the hood, the small tube that runs up the pass side fender to the fire wall sometimes snaps.
    the actuators only work the blend door for hot or cold air.
  4. #4 Re: Blend Door Actuator Replacement
    Nov 2009
    near Pittsburgh, PA
    Thanks!
    Well, as luck would have it, my problem actually was the knob itself that had broken. But wow, I was looking under the dash as to how to get the front of the dash off, and it looks like (from what I've seen here as well), you have to start at the center console and work your way forward? Man, I'm glad the stock radio was good enough for me!
    So. "vice grip" knob hanging off the dash, it's off I go!
    Thanks again,
    Tom
  5. #5 Re: Blend Door Actuator Replacement
    Nov 2010
    Hannibal, MO
    We have a 2003 GT w/dual climate controls. Could someone please tell me where the actuator is? Thanks. Dan.
  1. Blend door
    By BADAZGTP in forum General Tech Discussion
    Last Post: 06-27-2016, 02:25 AM
  2. Blend Door
    By 98GTPON22s in forum General Tech Discussion
    Last Post: 03-07-2012, 09:50 PM
  3. Temperature Actuator
    By s7falcon in forum Shops and Community Heroes
    Last Post: 09-04-2009, 11:36 AM
  4. 97 grand prix gt 3.8 liter ac blend door actuator
    By king1997 in forum General Tech Discussion
    Last Post: 06-18-2009, 07:58 PM
  5. Throttle Actuator
    By chrisothoulos in forum General Tech Discussion
    Last Post: 05-22-2009, 03:56 PM
