Thread: Hooking up NGK AFX Wide band to HPtuner
Results 1 to 9 of 9
  1. #1 Re: Hooking up NGK AFX Wide band to HPtuner
    for a AEM 30-4100 it should be:
    ([PID.2811]*2)+10
    Concerned about accuracy though.
    11 AFR would be 1 V which over the length of wire from the gauge, to the EGR harness to the PCM would probably drop... Will look into this further.
  2. #2 Re: Hooking up NGK AFX Wide band to HPtuner
    SE Level Member JerzNick's Avatar
    Oct 2012
    New Jersey
    ([PID.2811]*2)+10
    Come up with anything Matt? I'm using the AEM 30-4100 with the param you recommended and my AFR on HPT pretty much doesn't move.
    Bored block, Eagle Crank, XP Cam, Ported Heads/LIM/Blower/TB, 3.0 Pulley, CAI, Headers, 42.5#, AL 104's, etc...
  1. Narrow Band O2
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 06-06-2009, 10:59 PM
  2. Good Wide band
    By TheOtherNick in forum General Tech Discussion
    Last Post: 05-24-2009, 01:00 AM
  3. help please?! forward band?
    By LuvMyGTPMostDays in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-18-2008, 09:08 PM
  4. hooking up gauges
    By GTPRiley in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-03-2008, 03:07 PM
  5. help hooking up a bosch o2 sensor
    By TDCRacing in forum General Tech Discussion
    Last Post: 05-15-2008, 07:19 AM
