Thread: hooking up gauges
Results 1 to 12 of 12
  1. #1 hooking up gauges
    GT Level Member GTPRiley's Avatar
    Oct 2008
    Abilene Texas
    Hey guys I need to know what wire to tap into on the PCM side for the O2 sensor signal.... did a search... nothin, I did read the directions and it doesnt say anything thanks guys just need to know the color of the wire... thanks!
    also where is the sending unit located for an oil pressure gauge... thanks guys!
    ps 2004 Grand Prix GTP CompG if that helps.
    Riley Greear
    "Bastardized" 2004 Grand Prix GTP Comp G. 180* Tstat, Fender Well Intake, AL 104's SSAC Headers 3.5 MPS XP-HOT Cam and 105# springs.
  2. #2 Re: hooking up gauges
    Barksdale AFB, LA
    Tap it at the connection for the O2 sensor. I think it's purple/blue.
    2009 Subaru Impreza WRX STI
  3. #3 Re: hooking up gauges
    Oct 2008
    Abilene Texas
    Thanks Sabre knew I could count on you lol! later
    Riley Greear
  4. #4 Re: hooking up gauges
    Oct 2008
    Abilene Texas
    how about the location of the sending unit thanks
    Riley Greear
  5. #5 Re: hooking up gauges
    Barksdale AFB, LA
    Quote Originally Posted by GTPRiley View Post
    You mean where is the connection?
    Here:
    http://img.photobucket.com/albums/v3...orlocation.jpg
    It's connected to the bracket the engine cover slips into at the back of the engine bay.
  6. #6 Re: hooking up gauges
    Feb 2008
    The oil pressure sensor is located on the back side of the engine block right above the oil filter.
  7. #7 Re: hooking up gauges
    Barksdale AFB, LA
    Doh! Completely skipped over him asking about the oil pressure sensor. You sure your gauge will read that sensor correctly?
  8. #8 Re: hooking up gauges
    Odessa, MO
    Quote Originally Posted by Sabrewings View Post
    Ditto. Most aftermarket gauges require their own sender to be used.
  9. #9 Re: hooking up gauges
    Feb 2008
    ^^^ yeah get a couple adapters and you could use both.
  10. #10 Re: hooking up gauges
    Barksdale AFB, LA
    Will the ZZP pigtail work for him since (judging by his avatar) he has an 04+? The ZZP page says it's only for L36/L67 engines.
  11. #11 Re: hooking up gauges
    Feb 2008
    Hmm good eye, it will not work!! I even looked up the o2 sensors and they are different as well. Interesting there isn't one of these for the 04&^
    **Post #6 has been edited**
  12. #12 Re: hooking up gauges
    Oct 2008
    Abilene Texas
    its cool I got them all hooked up, My gauge came with its own sender unit, the 02 gauge is spliced into the purple wire on the o2 sensor.... ( narrow band Im assuming, speaking of which Will someone explain the difference between narrow and wide, and explain how to make a wideband system....)
    and the boot gauge is ran into the vaccum system, Installing a 180 thermo today, and how do you reach the plugs on the back, because I have AL 104's Id like to throw at it... Im getting it ready for a smaller Pulley... Thanks guys sorry to not have responded all weeked was out of town with no internet!!!! "YIKES!!!!"
    Riley Greear
  1. Gauges
    By ssm90GT in forum General Tech Discussion
    Last Post: 10-14-2008, 07:30 PM
  2. Gauges
    By 99prixgt in forum General Tech Discussion
    Last Post: 09-25-2008, 11:48 PM
  3. help hooking up a bosch o2 sensor
    By TDCRacing in forum General Tech Discussion
    Last Post: 05-15-2008, 07:19 AM
  4. Gauges
    By GP2003GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-15-2008, 05:54 AM
  5. What are the first Gauges to Buy
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-05-2008, 03:43 AM
