Thread: How to relocate your coil pack to the back side of your motor for 97+ n/a
Results 1 to 20 of 26
  1. #1 How to relocate your coil pack to the back side of your motor for 97+ n/a
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    Okay this is a how to for moving your coil packs on an 04+ na to the backside of the motor. I originally got this idea from the F body Camaros and seeing their coil packs sitting on the side of the motor.
    Things you will need
    #1 F body coil pack plate from camaro/firebird
    #2 Two 2 1/2 long bolts
    #3 Two nylon lock nuts
    #4 12 washers
    #5 Spark plug wire the length of your third shortest one
    Tools needed
    15mm socket
    13mm socket
    7/32 socket
    E8 torque star socket
    15mm open end wrench (ratchet wrench or pass through socket are lot faster)
    Vice grips
    DISCONNECT THE NEGATIVE BATTERY TERMINAL
    #1
    Step one is mount the plate. There are two tabs that stick off of the fuel rail on the backside of the motor. You may have to move some wires around so that everything is below that point. I used 6 washers on each side to shim the plate up higher so it wasn't rubbing the tops of the injectors or the wires. Next I made a bracket then mounted onto the side of the plate down to the bracket that the support bar from the alternator mounts to. You will have to tweak the fuel line a little so that the coil packs can sit and nothing's rubbing.
    #2
    Step two is to remove the coil packs start by disconnecting all of the spark plug wires. Then remove the 6 bolts holding the coil packs down with the 7/32 socket some say it's a 5.5mm I think the 7/32 fits better. Once you have the coil packs out of the way remove all of your wires. Set the board that the coil packs sit on to the side. Then remove the three nuts underneath the coil pack plate this is where a pass-through socket or ratchet wrench will come in handy once those are removed use the E8 Torx star socket and remove the two studs that are there.
    #3
    Step 3 is to move the electronic board that the coil packs sit on up to the new place. Install the coil packs in the same order that they were before. Then reroute your current wires that you have to where they need to go. The shortest of your 6 wires is going to be too short to reach anything this is where that extra wire comes in. Reconnect your battery and your good to go.
    (Pics will be posted shortly)
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  2. #2 Re: How to relocate your coil pack to the back side of your motor on 04+ n/a
    Buffalo
    Great thread so far! Been waiting to try this
  3. #3 Re: How to relocate your coil pack to the back side of your motor on 04+ n/a
    Jan 2013
    leavenworth ks
    Thank you!
  4. #4 Re: How to relocate your coil pack to the back side of your motor on 04+ n/a
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Nice write-up bud!
  5. #5 Re: How to relocate your coil pack to the back side of your motor on 04+ n/a
    Apr 2012
    Bancroft. Ontario, Canada
    and this wont work with 97-03 why?
  6. #6 Re: How to relocate your coil pack to the back side of your motor on 04+ n/a
    Jan 2013
    leavenworth ks
    Quote Originally Posted by Speedy1973 View Post
    It probably could I just don't have a 97 - 03 so I didn't want to give out wrong information
  7. #7 Re: How to relocate your coil pack to the back side of your motor on 04+ n/a
    Buffalo
    I'm assuming it's similar as most here have 97-03s
  8. #8 Re: How to relocate your coil pack to the back side of your motor for 97+ n/a
    Jan 2013
    leavenworth ks
    I have adjusted the name lol
  9. #9 Re: How to relocate your coil pack to the back side of your motor for 97+ n/a
    Waiting on those pictures
    Sent from my KYOCERA-C6745 using Tapatalk
    04 Comp G.
  10. #10 Re: How to relocate your coil pack to the back side of your motor for 97+ n/a
    Apr 2015
  11. #11 Re: How to relocate your coil pack to the back side of your motor for 97+ n/a
    Jan 2013
    leavenworth ks
    Thank you for posting those for me Jared
  12. #12 Re: How to relocate your coil pack to the back side of your motor for 97+ n/a
    Hmm not bad not bad.. I may just have to give this a try and see if there's any clearance issue when it cokes to us sc guys
    04 Comp G.
  13. #13 Re: How to relocate your coil pack to the back side of your motor for 97+ n/a
    Apr 2012
    looks pre decent!
  14. #14 Re: How to relocate your coil pack to the back side of your motor for 97+ n/a
    Apr 2015
    Quote Originally Posted by Travisgt2 View Post
    Sure thing Travis.
  15. #15 Re: How to relocate your coil pack to the back side of your motor for 97+ n/a
    Jan 2013
    leavenworth ks
    Thank you speedy thank you red
  16. #16 Re: How to relocate your coil pack to the back side of your motor for 97+ n/a
    GT Level Member WickedGoat's Avatar
    Dec 2014
    Missouri
    Not to take anything away from the OP, but wouldn't a set up from the the 97-03 3.1's work for the 97-03 cars? Just thinking out loud since I was under the hood of my in law's 99 Buick Century with a 3.1 and the coils are located on the back of the engine. I have no interest in doing this but for those that do, it might be worth a look at. Junkyard parts should be plentiful and cheap...
    2014 Chevy Impala LTZ Limited -- Silver/Black, Grand Prix replacement
    2004 Pontiac GTO -- my garage queen
    2004 GMC Yukon SLT -- wife's daily driver
  17. #17 Re: How to relocate your coil pack to the back side of your motor for 97+ n/a
    Jan 2013
    leavenworth ks
    Quote Originally Posted by WickedGoat View Post
    Honestly I have no clue I'm just putting out the knowledge I have and how I did it. If some one has more knowledge for this thread I'll incorporate it in and add it. It would be good to know where more similar parts are. Thank you.
  18. #18 Re: How to relocate your coil pack to the back side of your motor for 97+ n/a
    It would because it's common with the turbo guys.
  19. #19 Re: How to relocate your coil pack to the back side of your motor for 97+ n/a
    Jan 2013
    leavenworth ks
    That's why I did it was a pre turbo thing to get ready for it
  20. #20 Re: How to relocate your coil pack to the back side of your motor for 97+ n/a
    SE Level Member james782004's Avatar
    Nov 2015
    Nice! I'd love to do that but I'm too short to change plug number 3 as it is 😞 that would make it more of a challenge to get it for me. Any whooo great job!
    Sent from my SM-G920R4 using Tapatalk
  1. Same coil pack keeps going bad
    By xxburkettxx07 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-26-2015, 06:54 PM
  2. Coil pack not firing!
    By jordan89 in forum Introductions/Noob Questions
    Last Post: 05-19-2014, 11:24 PM
  3. coil pack
    By kenconerly in forum General Grand Prix Discussion
    Last Post: 11-18-2012, 02:57 PM
  4. coil pack
    By chancinit666 in forum General Tech Discussion
    Last Post: 06-13-2010, 12:22 AM
