Thread: Removing Tie rod ends
Results 1 to 18 of 18
  1. #1 Removing Tie rod ends
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    so i bought some tie rod ends off of ebay.
    i was looking at the picture, and i dont see how they gripped to be installed or removed, but i might have the process all wrong in my head. (never changed before)
    whats the general process for a wbody?
    parts http://www.ebay.com/itm/291426698043...%3AMEBIDX%3AIT
    (yeah i know cheap probably should have bought better ones)
    doesnt look like there is anywhere to grip
    (sorry if its in the wrong forum)
  2. #2 Re: Removing Tie rod ends
    SWPA
    There is a square part on it you can grip. Really you hold the tie rod and turn the locknut.
  3. #3 Re: Removing Tie rod ends
    Make sure you spray stuff down with some pb blaster to make removing the bolts easier.
  4. #4 Re: Removing Tie rod ends
    Antioch, IL
    Just wait until the stud spins and you cant get the nut off
    2009 Challenger SRT8
    Expert at being gay.
  5. #5 Re: Removing Tie rod ends
    Quote Originally Posted by ITHURTZ View Post
    That happened on mine, I just busted out the sawsall.
  6. #6 Re: Removing Tie rod ends
    that only happened one time to me. and it was a truck. i was able to pound it back in the knuckle and got the nut off.
  7. #7 Re: Removing Tie rod ends
    SWPA
    You place a pry bar under the steering knuckle and pry down on the top of the tie rod and the nut will zip right off.
  8. #8 Re: Removing Tie rod ends
    Sep 2014
    Richmond Virginia
    is it going to need an alignment?
  9. #9 Re: Removing Tie rod ends
    Quote Originally Posted by 04lss View Post
    100% will need one.
    when you take the old ones off, crack the lock nut free and leave it loose next tot he old rod end. take the outer rod off, and leave the lock bolt in place.
    now install the new rod to the lock nut, and tighten it, then go for an alignment, it will be close but not perfect.
  10. #10 Re: Removing Tie rod ends
    Buffalo
    Heat. Once you lossen the jam nut, heat it and turn it.
  11. #11 Re: Removing Tie rod ends
    never heated up a lock nut in my life, the inner rod has a square part on it, put a large adjustable wrench on the bar, another wrench on the lock nut and bust it free.
  12. #12 Re: Removing Tie rod ends
    Buffalo
    No ding-dong. Loosen the jam nut. Heat the tie rod. That is IF he is having difficulty removing it "HEAT IT BEFORE YOU BEAT IT"
  13. #13 Re: Removing Tie rod ends
    Sep 2014
    Richmond Virginia
    off topic to thread, but does anyone know the axle nut size? ive heard 34 and 35, and im wondering which one to borrow from advance.
  14. #14 Re: Removing Tie rod ends
    Buffalo
    That's the thing. It could be any size if it was replaced before. Because the aftermarket cv shafts come with new nuts and they are typically not the same size as the original
  15. #15 Re: Removing Tie rod ends
    get a 34 and a 36. truth is a 36 fits a 34 and works, ive done it. i got one of both sizes on my car.
  16. #16 Re: Removing Tie rod ends
    Sep 2014
    Richmond Virginia
    so borrow the axle nut kit from advance i guess.
  17. #17 Re: Removing Tie rod ends
    SWPA
    Or spend $10 on a socket and have it.
  18. #18 Re: Removing Tie rod ends
    Buffalo
    Lucky for me my center cap comes off the gsx wheels so I can test the sockets right in the parking lot
  1. Removing A/C condensor without removing radiator?
    By 97AutoXVette in forum General Tech Discussion
    Last Post: 04-02-2014, 07:43 AM
  2. Ah, the fun never ends.......
    By traildog in forum General Tech Discussion
    Last Post: 01-13-2014, 08:20 PM
  3. Tie Rod ends
    By Bigjrivers in forum Brakes/Suspension/Chassis
    Last Post: 11-21-2012, 08:30 PM
  4. Tie rod ends
    By GranPri in forum General Tech Discussion
    Last Post: 02-02-2011, 02:18 PM
